Question about Kenmore Dehumidifiers
The fan is not moving so the engine is binding. Can't remove the top to see what is causing fan to stop.
  • Kenmore Master
  • 43,501 Answers
the bearing have siezed up on the fan... some WD-40 and then some oil may get it going agian...
heatman101
Posted on Aug 29, 2010
The fan never stops running. The dehum. works fine that is the only problem. Is it the way I have it set how can I change that?
Bob, some humidifier fans run a lot, because they are designed to keep the air moving and when the humidity level rises, the compressor turns ON to extract the humidity. If you're operating the unit in a continual mode, it's not unusual for the fan to run almost constantly.Especially, is the humidity extraction level is set at or above 50%. Lowering it to 35% will cause it to extract more humidity and will turn on an off less.
Hope this helped you and thanks for choosing FixYa.
Sep 19, 2011 | Whirlpool AD50USL Dehumidifier
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
My Kenmore dehumidifier has stopped drawing water from the air to the collection receptical. Fan still runs at high and low speeds.
A couple of things may be happening: The humidity extraction level may be set to high and it can't extract any humidity at that level. Reset/Lower it to 35%. The fans on most dehumidifiers run almost constantly (designed that way) so that it keeps moving the air around. If the sensor picks up a higher humidity level than what it's set to maintain, the compressor will turn ON. This is particularly true, if you operate the unit in continual mode, rather than a timed mode. Also, a dirty or clogged air intake filter, hinders the units ability to remove humidity/moisture.
In addition, operating the unit is ambient air temperature of between 40 & 60 degrees F, causes the unit to struggle to dehumidify the air and the fan to run continuously. Obstructing the air flow around the unit, will also cause it to not function as it should. Maintain a minimum of 12" of free air space around all 4 sides of the unit.
Hope this helps you troubleshoot and solve the problem. Please let me know.
May 28, 2011 | Kenmore Dehumidifiers
Compressor stops at proper humidity % but the fan keeps running.
Dehumidifiers are built that way. They keep moving air so it is able to keep any change of conditions moving around the room. On a dehumidifier, it the fan stops, your unit will short cycle becasue water will naturally evaporate from the water tank and it would turn on, then off, then on then off. The way it runs now is fine. Running the fan 24 hours on your dehumidifier cost nickels a day. Just let run.
Sep 28, 2010 | Danby DDR2504 Dehumidifier
54701 very few running hours. All works but fan wll not run,turns freely no binding. what is the fix??
Number 1 check to see if you have power to fan may have to back track to check switch also check capacitors make sure there are no broken wiresa in fan circut
Jun 11, 2010 | Kenmore 54501 Dehumidifier
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
How does the unit collect water?
Your fan motor is going out. You can remove the screws from the back cover and gently pry it off. After that, look into the unit and you will see the screws holding the front cover. Take the bucket out and remove the screws at the top. All the screws around the entire metal shroud need to come out. Then with the covers off you can see the fan mount screws. You have to move the evaporator very gently out of the way to get to these screws. Remove the fan motor replace it and re assemble the unit.
Oct 03, 2009 | LG LHD65EBL Dehumidifier
Fan motor stopped working, replacement went out too!
I would look for another outlet for you to plug it in before you start anything elaborate. I assume you've done this already but spin the motor/blade. If it spins and there is little or no play in the shaft or blades causing a blade to bind up the mechanical part seems ok.
Now if you have a volt meter First check the motor for voltage, Then if you have voltage, compare it to the rating on the motor. Usually a voltage within 10% is ok. Next test resistance on the wires of the motor any resistance and the winding is probably okay. If not then the motor is out again. If you have lost voltage the control board is your next part to test. No voltage out to the motor there on the board plug and the board is the problem Power there woudl mean the motor has too high a resistance and Id check the resistance on a differant known good motor before replacing it. just so you know where you started.
Mar 10, 2009 | Goldstar DH3010B Dehumidifier
Problem with fan
just replace the fan motor is the proper fix. you may dissasemble the fan motor and it may run for a while but the cost of a compressor is not worth the cost of the fan motor
Apr 23, 2008 | Kenmore 54501 Dehumidifier
Condensation
i might . let me know if you still have this
Nov 03, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
77 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
