Question about Coleman Mach 15 Air Conditioner
How to add freon to a coleman mach model# 8633-876 serial # 089817583 do you suggest r12,or r22 freon type. is this a easy procedure or does it take a ac person? the problem is it not cooling to full capasity. also drips inside houseboat. compressor is coming on just doesnt get real cold.
    Guru:
  • 587 Answers
It's R-22 and you need to be licensed to handle it, if you're not a A/C service technician or fimiliar with charging an A/C system, then it is best to have a Coleman Service Technician to charge it for you.
Posted on Aug 31, 2010
What kind of freon was used in this unit when made
You didn't give a model or brand so here is what to check. Find the model--serial tag on the air conditioner and it should tell you type of freon and usually the amount. Most older air conditioners were freon R22.
May 20, 2015 | Heating & Cooling
Can 22 refrigerant be used in refrigeration?
I was under the understanding that R22 was for AC units only, R134 is current along with R409 (hotshot), prior to the was R12 dated 1995 and earlier. Due to the expansion properties needed for R22, I would not mix this with any other freon.
Aug 09, 2014 | Refrigerators
How to do a freon recharge on roof top rv airconditioner
there are no access ports to add freon you would have to put a line tap valve on it.
May 10, 2014 | Coleman Mach 15 Air Conditioner
Where do you recharge the AC with r22?
Most rooftop RV units do not have service ports installed. You would have to get line tap valves to install in the system. The next problem would be getting some R22. Unless you have and EPA CFC certification you cannot buy R22.
Sep 25, 2010 | Coleman Mach III Air Conditioner
Roof air not cooling, what is the correct freon to add r22?
On the outside of the unit on the cover,there is a nameplate rating that should tell you how much and what type of freon is in it.
Jun 29, 2010 | Coleman Mach 15 Air Conditioner
What should refrigerant gauges read when charging walk in freezer?
Depends on what kind of refrigerant its works, if is an old unit probably is charged with R12 or R22 newer ones work with R404 ;for R12 presures should be around 20psi on the low side and 160 on the high side ,for R22 about 60 and 250 and for R404 50 and 350 ;you have to look at the condensing unit tag to find out what type of freon its uses ,or look at the expansion valve at the evaporator coil.
Jul 31, 2009 | Everest Refrigeration Freezers
Why type of freon goes into a coleman AC, 1994 Fleetwood Country Villa?
After some searching it sems to use R-12 freon. It is getting a bit hard to come by and you have to be licensed to purchase it.
Jul 06, 2009 | Coleman Mach III Air Conditioner
CAN R12 BE ADDED TO AN AC HOME UNIT USING R22.UNIT IS RUNNING BUT NOT COOLING
No, R12 and R22 are not compatible freons. You need to recharge with R22.
Jun 30, 2009 | Whirlwind FH-778 Air Conditioner
Air conditioner needs freon
If the system runs you will first need to add freon to the system (make sure it the right freon) Just enough to find leak. After you find leak and repair evacuate the entire system and weigh in charge. Hope this helps.
Feb 09, 2009 | Heating & Cooling
Coleman Mach 15 Air Conditioner Logo
920 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
