I have a beckett R7184 b unit that The light has gone out on . We originally had water in our tank that caused our original problem, which a service tech said we would have to drain the tank . He replaced the nozzel and filter and I drained the tank and bled the line .it worked for about a day and then locked out again . Once again there was water in the lines I bled them again and fired it up again . The unit must have worked a few days and then it stopped . I checked the beckett unit and noticed no light on this time . Filter is clean oil is bled no water . Please help
ranger25
  • 72 Answers
SOURCE: Hotpoint MAC-130 air conditioner dripping water
You need to blow out the drain line where it hooks up to the pan and clean out the drip pan. It doesn't matter how clean you keep the filter, that's just to keep the evaporator coils clean, which is important in itself. But algae will grow in the drip pan if it is not tilted to drain correctly and will clog up the drain line. If you put a level on the top of the unit, the bubble should JUST BARELY break the line on the OPPOSITE side from the drain outlet on the pan. Hope this helps.
Posted on Jan 27, 2008
Master_Tech
  • 770 Answers
SOURCE: Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Posted on May 10, 2008
  • 38 Answers
SOURCE: machine can't get rid of the water gives no drain message
The motor is burnt out. When it is cool it will pump water out, but as it heats up and the insulation on the windings break-down is short-circuits and stops.
Posted on Jun 01, 2008
SOURCE: ALL LIGHTS BLINK BUT UNIT IS DRAINED
Hi all,
I think the problem is that the A/C has tripped the electrical switch located in the plug. To correct press the black button followed by the clear button. Then try turning the unit on -it has worked for me so no reason it should not work for you.
Regards,
Tommie C.
Posted on Sep 02, 2008
  • 104 Answers
SOURCE: beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Posted on Nov 02, 2008
Asko D1606 won't fill, and sounds like pump is running
This means the unit has taken on water to the base pan and will not allow you to do anything until the water is removed. Once the water is gone you will need to locate or fine why water reached the base pan to correct this problem. Most common reasons, too much subs, leaking hose, leaking drain hose behind the unit and traveled back into the unit. Without seeing the unit the cause would just be a guess. I hope this helps. If you unplug the unit allow 2-3 days to dry out, this may allow you to run the unit and locate the original cause of your leak. good luck
Mar 26, 2016 | Asko Dishwashers
Need Rheem part number
Is this a tank water heater? The label on side of tank will give model number:
http://waterheatertimer.org/Rheem-water-heater-parts.html
Add a comment and describe product you are working on.
I do not have resources for Rheem HVAC
Jun 18, 2013 | Water Heaters
My Hoover steam vac spin scrub will not suction up the cleaning solution . Why is there no suction?
p{margin-top:0px; margin-bottom:0px;} Hello,
Thank you for your recent e-mail. I am sorry to read about the problem that you are having with your cleaner.
Please make sure your recovery tank and lid are installed correctly and forming proper seals. Make sure that your filter is clean of any debris. Clean the screen in the tank lid. Make sure your nozzle and squeegee (if on your model) are free of dirt/lint/hair and attached in their holsters correctly. Make sure you do not have any clogs in the hose.
To restore suction, please try the following:
*Remove dirty water tank and clean filters- main reason for low suction is dirty filter
*Verify the dirty water tank cap is not missing.
*Verify dirty water tank lid is inserted completely into unit.
*When cleaning, the yellow float inside of dirty water tank should be free moving.
• First remove your clean water tank and unplug the machine
• Remove the dirty water tank lid and push the front panel piece (square plastic sliding piece in the front of tank) down to make sure it is inserted all the way.
• When reattaching the lid, hook the tabs on the front of the lid to the tank first, then click shut in the back. Pull up on the lid firmly, it should not lift at all. If it does, try reattaching as a seal needs to be formed for suction.
• Test to see if suction has been regained.
If these suggestions do not solve your issue please call a service center.
Your cleaner has at least a 6 month warranty for manufacturing defects. This warranty begins from the date of purchase, with the original sales receipt. If you do not have the original sales receipt, the warranty may be verified at the warranty repair center by MFG or serial number.
Please visit www.Hoover.com and click on service center locator for a list of authorized dealers in your area for service and warranty assistance.
Sincerely,
Hoover Customer Service 62
1-800-944-9200
Mon - Fri 8am to 7pm EST
**Please do not reply to this email address. This is for outgoing messages only.**
servlet.imageserver?oid=00da0000000yf5q&esid=018g0000005bxv6
ref:_00DA0Yf5Q._500G0AodT5:ref
Aug 08, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My unit is flashing a red light in the water full indicator. Therefor the air conditioner will not function. Both water tanks are completely empty. It is a portable Danby unit. Model SPAC 8499-3. Any...
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
Sep 09, 2011 | Danby Heating & Cooling
We have a Beckett W5000 a rock got in the systems and broke the plastic puppelor. Where can we buy trhe part to fix it???
Email Beckett at: customerservice@beckettpumps.com
Call Beckett at:
972-871-8000 or Toll Free at 1-888-BECKETT (232-5388)
Fax Beckett at:
972-871-8888
Write to Beckett at:
Beckett Corporation
c/o Customer Service
3250 N Skyway Circle Dr
Irving, TX 75038
Warranty & Technical Assistance:
The NEW toll free number for warranty information, replacement parts, and technical assistance with water gardening and fountain products is 866-466-4319 or email Beckett atCustomerCare@beckettpumps.com
For information on CE, VDE, or DENAN (PSE mark) certified pumps:
Please email Beckett at: customerservice@beckettpumps.com
Or write to them at the address above.
Aug 28, 2011 | Beckett Water Gardening Beckett Statuary...
Where do I locate screw to bleed my pump on a beckett honeywell R7184 series.
Too the right side of the pump. There is a 3/8 nipple sticking out. With a wrench open it reset and run till you get fuild close off and off you go
Mar 23, 2011 | Honeywell Heating & Cooling
We have a Beckett Pond Heater and when we placed it in the pond this year it went to the bottom and will not float. It seems to heat, but we are expecting thick ice. Any suggestions?
The purpose of the heater is maintain an open water space on the surface for gases to exchange into the water. Whatever was in place to keep this unit afloat must be replaced (ie Styrofoam). Or, if the the unit has an air chamber to keep it afloat perhaps the element burned through it and it's filling with water.....try to plug it with some epoxy glue.
Nov 15, 2010 | Beckett Corporation Beckett 7137010 Rock...
Beckett home oil burner
Nov 01, 2008 | Water Heaters
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
