Question about Sony Video Cameras
I was using my handycam DCR-SR68E in an open park. I have no clue why, but suddenly the recording stopped. I could see an error where the handycam was attempting to recover the data. and the end result was pretty ugly. I can now read "HDD format error" when i connect the handy ca to my pc. My pc cannot detect the external device. I am afraid that I have lost all of my data. Any help in this regard would be highly appreciated. Thanks in advance. Nimish Inamdar
  • 6,831 Answers
Hello
Download THIS.
Download this free tool and run it on you card and it should be able to recover all pictures provided that you have not used the card since formatting. I recommend using a card reader for this.
After downloading and running (no installation required) , simply select deep scan and your memory card and it will start scanning, To recover a found file , right click it and select save.
Please note that the file names will probably not be available and also that some of the properties of the photo like date taken could be lost.
Please let me know when you have recovered your pictures safely or contact me if you need further assistance.
Regards
Andrea
Posted on Aug 29, 2010
  • inimish Aug 30, 2010
    Hi Andrea,
    Thanks a lot for the recommendation.
    I do have an issue in your suggestion.
    I see the error E:31:00 flashing on the left hand side upper corner of my screen.
    In this my hard drive is not getting recognized, and hence I cannot install the application you have suggested.
    Since it is not a SD card, but a hard drive, I cannot read/write the card using any memory card reader.
    Can you help further?
    Thanks in advance.
Buffer over flow movi recording time
The error description is not very precise. Anyway:
You should check the Harddisk for Filesystem errors/defective blocks. Don't know if the Camcorder has a built-in function for this. It could also help to delete all data and to reformat the drive.
Otherwise you may need to replace the harddrive (While you are at it, you could put the drive into an external USB cage and check it with your computer). Sounds like a complicated task.
Jan 17, 2014 | Sony DCR-SR68E/S Handycam(R) PAL Video...
How to download hard drive to computer
the manual explains all that. lost it?
if yes, its on the sony site.
i have the same cam.
1: connect their cable.
2: load CDrom, and load the Sony USB software.
it needs special uSB drivers for older OS, (unstated OS)
3: run said software. or see the files via program manager.
what computer, PC or MAC, or Linux?
Oct 03, 2013 | Sony DCR-SR68E/R Model DCR-SR68E Handycam...
Can I Download Soft ware of Sony Handicam DCR- SR68E ?
Software is not required to download the videos from this Camcorder.
Jan 17, 2013 | Sony Handycam DCR Series DCR-SR68 Digital...
HDD format error
Format the hard drive, if you still get that message the drive is broken and needs to be replaced by a professional.
Jun 11, 2012 | Sony DCR-SR68E/S Handycam(R) PAL Video...
I am using sonu handicam dcr-sr68..and it is showing formet error..and is not doing any work...pls help me
Possible there are errrors in the memory. transfer the recorded files and then format the drive. If not connect to the PC after downloading the software and check for errors. If not there are errors in the drive.
Oct 27, 2011 | Sony DCR-SR68E Flash Media, Hard Drive...
My new Sony DCR-SR68E shows hard disk format error and E:31:00 error every-time I star it. It doesn`t shoot anything. It doesn`t even get formated. Please let me know if there is anyway to solve this...
SonyDCR-SR68E HDD Format error
Go to Menu-Show Others-Media format-HDD-Yes-Yes-ok
you must be solve your problem.
Never format your camcorder with NTFS or FAT system format using your operating system Windows.
Sep 18, 2011 | Sony Handycam DCR-SR100 Camcorder
SONY HANDYCAM DCR-DVD105 ERROR MSG C:13:02
Try to use a cotton swap to 1st clean the recording lens or blow gently on it. Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Jun 28, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
My sony dcr-dvd105 handycam camcorder all of a sudden shows only
There is 2 possibilities, either aperture of camera jammed and doesn't open or CCD Imager got defective in your Sony DCR-DVD105 camcorder.
Let me know if you have little experience of camera repair to guide you further.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony Handycam E:40:00 Error Help
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Feb 12, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Video Cameras Logo
345 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
