When I put a dvd into the player the picture comes up ok but the sound doesn't and the sound from the tv programme can be heard instead. The dvd player displays 'root'.
  • 1 more comment
  • slim2u May 09, 2008
    I've unplugged the dvd and put it back in.
    Turn it on an off for about 10 to 15 sec.
    Clean the disc off and insert back in.
  • Anonymous Dec 29, 2008
    I am using an RCA DRC285 HDMI
    When I turn it on it says hello, and begins to read the disc. Sometimes the disc will even begin to play, but within the first five minutes (at the longest) the video shuts off, and the dvd player says 'root.' Once this happens nothing will work on the dvd player, including the power button, so I have to unplug it.
  • David Simpson May 11, 2010
    How is the DVD connected to the TV?
    • Scart
    • Composite video - yellow phono connector (RCA)
    • Component video - red / green / blue phono connectors (RCA)
    • S-Video - 4 pin mini DIN
    Also do you have a secondary audio connection - red / white phono (RCA)?
  • 476 Answers
Cleared
Posted on May 28, 2008
Samsung hdtv, I have sound but no picture. This is an older tv, I have had it for about 6 years.
Have you try watching using a DVD player on your t.v if doesn't try watch on it using a DVD player but if still it doesn't have a picture but only sound perhaps there is a problem with your HDTV.
Jul 01, 2011 | Samsung PCL5415R TV
LCD TV connection to DVD-VCR
OK here is a possible solution: 1) The best solution: Connect the antenna to your DVD-VCR through the RF Input and the the RF Out to your TV This take care of the VCR part. Then you get an RCA three way cable (Video-yellow marked, Right Audio-Red marked, Left Audio-white marked)connect the yellow marked RCA cord to the Video out of your DVD player then connect the other end to your video in of your TV. Ater that connect the red marked audio cable to the R Audio out of your DVD player to the R Audio in of your TV do the same for the white marked Audio cable. You will now be able to switch from VCR-RF to DVD-RCA.
Sep 11, 2007 | Televison & Video
I just moved, and hooked up the cable,, dvr successfully, and my dvd/video player in. I get a picture with my dvd;s, BUT no sound. two people have told me all the wires are connected properly and i...
To identify where the problem is you will have to do some tests: first just replace the wires/the data cable. Then plug something else in those cables - instead of the player: if the problem remains you will know that the defect is in the tv, if not - it's in the player.
If it's in the tv the first thing you should check is if the sound isn't muted on that AV input - some tv's allow that. Then you must check the connectors themselves: put the volume at maximum and touch the inside part with your hand (you will probably need a small fine screwdriver for that) - if the connectors themselves or the AV switching circuits are ok a very loud white noise will be heard.
If you don't hear it then there is a faulty part and the only way to find it out is to open the tv and test the components using very special equipment - a job for a pro.
Oct 17, 2010 | Sanyo Televison & Video
No picture on dvd screen - has sound put on picture
hi
if there is any out put check it in external tv or monitor or lcd
if it is ok on external monitor your player lcd got problem 1- hi voltage that connect to lcd Fluorescent (has 2 wire)
2 - or Fluorescent is broken
Jul 29, 2010 | Cyberhome CH-LDV 712 Portable DVD Player
When i connect my dvd player to TV i only hear sound but no picture
hi there
your dvd player got three cable one red two white
three yellow ok here i go dvd player input plug in the yellow cable in the yellow in put @ the back of your dvd dvd player
the white cable and red cable is your sound the yellow cabe is your picture see that you have a yellow input @ the back of you tv and plug in the yellow in it then it will work
Dec 14, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
DVD sound a problem but is playing ok.
try changing your dvd audio settings to stereo
Nov 12, 2008 | Toshiba SD-2800 DVD Player
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
Electro Med Services...
