Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Washer spins too fast even on low speed - makes lots of noise
TheMobilian
  • 8220 Answers
SOURCE: Roper washer ras7133kq1will not spin enough to wring out clothes
bad motor most likely. easy fix
Posted on Feb 05, 2009
mikedurland
  • 481 Answers
SOURCE: Whirpool Ultimate Care II washer Imperial Series spins at low speed
Posted on Aug 12, 2008
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
  • 351 Answers
SOURCE: washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
voodoomox
  • 1689 Answers
SOURCE: washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Posted on Sep 10, 2009
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
The washing machine is working alright but when its spinning, theres a noise that sounds like its something broken inside... But u cant hear the noise when its on fast spin.
Can be front the drive at the bottom of the washer. I assume this has a high speed spinning and so there is a gear box which can be having less lubrication. So make sure that the motor drive section of the drum shaft assembly is well lubricated so that the noise at high speed reduces.
if you can do a mechanical job , it will be good to remove and reset with good lubrication and maybe replacement of the bearings.
Jan 20, 2011 | LG WD-16115FD Front Load Washer
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Spin cycle works sometimes, or does not spin hard enough to remove most of water
Many high-end washers have two spin cycle speeds. The low speed is for delicate fabrics. Yours may be stuck in the low speed. Check that you are selecting the wash cycle with the high speed spin.
If you are and it continues to spin at the low speed then your controller is most likely at fault. Your gearbox could be bad too but it usually complains with a lot of noise.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The machine goes crazy when it's on the extended spin (fast spin). If I set it to "gentle spin, would it disengage the fast spin? Whirlpool didn't know the answer!
Even with a good level machine these are very heavy units containing 3 concrete weights. The floor is a direct contributor to vibration and yes it;s worse on the Ex spin with a higher spin speed. If it's on a wood floor even in a new home that can cause this issue. One way to make sure the machine is ok is to put it on a concrete floor, level it and hit the high speed spin with a wet load. Not a easy thing to do but one way to confirm it.
Even a normal spin is enough spin speed to extract enough water. Stick with that!
May 05, 2009 | Whirlpool WFC7500VW Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore washer weak agitate even at fast load and no spin
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
Aug 01, 2017 | Kenmore 43142 Front Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
