Question about Kenmore 15879 Built-in Dishwasher
Hi, I have a Kenmore 15879 that is basically working except the bottom water spinner...lol (don't know technical name). The dishwasher pumps the water into the bottom of the dishwasher, will heat the water, but not disperse the water in the spinning sprinkler manner it's suposed to. I've opened the dishwasher in time to see that water is spurting out of the holes about 2" high, but it's just not spinning. The water also drains just fine after the whole cycle.
    President:
  • 2,559 Answers
This is caused by the impeller being clogged or the pump is failing, When the pump is woring properly the water will shoot out with force.
Posted on Aug 29, 2010
Need manual for mod# 15879 kenmore dishwasher
http://www.managemylife.com/mmh/owner_manuals/14087/KENMORE-Dishwasher-L0504043
Feb 01, 2011 | Kenmore 15879 Built-in Dishwasher
Whirlpool Gold Dishwasher - GU2700XTSB The top rack of the dishwasher is not cleaning. The bottom rack dishes clean fine. There are no clogs in either the bottom or top spinner arms, the plastic tube...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Jan 20, 2011 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Top shelf not cleaning
Hi, the most likely cause of this is the sump is plugged under the screen area, I have put some instructions together to show how to clean out down there. let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 28, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My kenmore 665 dishwasher will not pump water to the lower and upper spinner arms. The pump entry screen assy seems to have one tear in it and is dirty. However water does come out if I take off the lower...
Good eye--- Pull kick panel and look underneath. use a bright light to see if there is any drippage or what looks like corrosion on bottom of aluminum motor case. If you see this crud, then motor/pump seal has failed and motor is bad. About 100 motor/100 labor. Let me know if info helps- ED
Mar 02, 2010 | Kenmore Dishwashers
Not cleaning Fills up with water at the bottom. Just not spraying. I took off everything inside to clean it out. Down to the grinding wheel. Pump feels like it running.
The water first gets pushed into the dishwasher from the water supply, then fills up until the float detects the water level, the water then gets drained into the sump pump and either drains to the plumbing or shoots up through the arm inside the dishwasher. Thats a basic cycle anyways. If it is draining into the sump pump like its supposed to, and not coming out through the arm, then something is blocking it or a solenoid/relay isnt working properly on the pump. If its not draining at all, which you would be able to hear if it were from the sucking or gargling sounds, then the same follows, just in different areas. I know its not to technical, just hoping to shed some more light on the situation.
Dec 28, 2009 | Kenmore 15129 Built-in Dishwasher
Won't drain
Please follow the steps provided bellow :
Fill washer with water and wait for the timer to get to the drain mode.
Unplug the washer from the electric outlet.
Open the case, and disconnect the water hose from the outlet of the water pump.
If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
Reassemble hose from step 3.
Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
Reassemble washing machine case...you're done...
Thanks for contacting Fixya.com
Aug 16, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The water spinners inside are not turning on top
These are the spray arms. If both are not operating - are you geting any water through them at all?
If no - then the fault is the circulating pump or control circuit. Not cheap I'm afraid.
Spray arms are usually ok.
If you are getting water throuh them, then remove them (2 clips or a large nut), and rinse them through. Oftem bits of food get past the filter, and end up blocking all the holes. Make sure they are all clear.
Jun 28, 2009 | Dishwashers
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore 15879 Built-in Dishwasher Logo
202 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
