Question about Sanyo 18KS52 Air Conditioner
Our sanyo ductless air conditioner is making a gurgling sound and a sound that is similar to a fog horn. what could be the problem?
Why does my sanyo model KHS2472 has a red light blinking in heat mode and a green in cooling mode, does not work in either mode makes a gurgling sound when it tries to run?
The red light indicates it's either heating or in defrost mode
Check the outdoor unit if the compressor is running - the large pipe on the outdoor unit should be hot on heating or cool to touch on cooling
When in heating mode - the indoor fan will not start until the indoor coil is warm enough
If the reversing valve that changes from heating to cooling is faulty then you may encounter the same symptoms too
Probably need a Refrig Tech to have a look at it?
Good luck
Jan 07, 2016 | Sanyo 24KS72 Split System Air Conditioner
My air conditioner give e3 error in turning on?
Mini splits are complicated. It sounds like it could be a humidity sensor or possibly you circuit board. Best to contact installer
Dec 21, 2014 | Sanyo 33,000 Btu Ductless Airconditioner
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
We have a split system and can not figure out how to heat different zones (ie bedrooms). Can you please help?
what kind of split system do you have is it a ductless split like shown or do you have actual duct work where you can change the dampers
Sep 18, 2010 | Sanyo Split System Air Conditioner
Sanyo propellor fan blade needed
I have the SAME EXACT unit and also need a fan blade - and Sanyo told me the same thing!
Jun 20, 2010 | Sanyo CMH3172 Air Conditioner
Air Conditioner leaking water
there is a drain that comes out the wall to the outside find it and **** it out with a good wet dry shop vac.
Oct 19, 2008 | Sanyo 09KHS51 Ductless Mini Split Air...
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Ductless heat pump systems
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Nov 15, 2007 | Mitsubishi MSH12TN Air Conditioner
Sanyo 18KS52 Air Conditioner Logo
32 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
