Question about Whirlpool GD2SHGX Refrigerator
Icecubes freeze together in a big lump in storage ,will not dispence
    President:
  • 1,218 Answers
Good day,
In almost all cases, that problem is due to the dual water valve located at the bottom rear of the machine. It is not repairable and must be replaced.
Assuming the freezer is staying at it's normal temperature, when the ice maker fills, the water valve described above does not shut off completely after a normal fill, causing water to dribble down the fill chute freezing the cubes together.
Very common problem, and changing the valve is not difficult, and most appliance parts houses carry them.
Posted on Aug 29, 2010
GE PSC25PSSC WILL NOT MAKE ICE
Sounds to me the WR57X10032 Water Inlet Valve
is sticking open on the ice maker side. Replacing the valve should solve this problem. I will be here should you have questions, Sea Breeze
Mar 06, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
R water fill keeps dripping after tray is full causing icecubes to freeze in box and arm will not turn to dispence ice
Good day,
That should be the water fill valve in the bottom back of the machine.
It is not shutting down completely, after performing each cycle.
This is due to a diaphragm in the valve having gone bad.
The only solution is to replace the complete valve assembly.
A fairly easy nuts and bolts job.
Before trying to dispense however, remove the bucket, and dump the ice. Forcing the auger drive motor can cause further damage.
Thank you for usingFixYa
Feb 09, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have hollow icecubes too, and water from the un frozen icecubes spills in bin and all the other cubes stick together. IS There Not a way to adjust the timer on the icemake to turn slower so they will...
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ROPER RT18AKXJW01 Ice Maker Malfunction
Hi, If the icemaker is leaking next to the head, all you can do is changethe icemaker. See if it is leaking between the head and the tray. You can order the icemaker off my web site www.whirlpoolpartssurplus.com. If I can assisrt you further, please let me know.
THanks
Vic
May 17, 2009 | Freezers
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
Whirlpool GD2SHGX Refrigerator Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
