Question about La Crosse Radio Controlled Watch
Setting after battery replacement - La Crosse Radio Controlled Watch
  • circusvet Aug 29, 2010
    reset after battery change
I sent my Lacrose radio controlled watch out to have the battery was changed now the vendor says that the display is _ _ _
what do I or the vendor do to set the the watch again
My email is georgesaufley@yahoo.com
Posted on Dec 29, 2010
Manual kenneth cole for watch ul 1181 where can i get the manual
i am not understanding ......
you need Manuel for replacing battery ?
or
you need Manuel for setting up digital part of your watch ?
Jul 28, 2014 | Kenneth Cole Unlisted Chronograph Watch
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
I have a Bulova westminster chime battery operated clock that the chime is off. how do I reset it?
You may call Bulova customer service at 1-800-233-3350 they are usually open 9 until 4 eastern time. It may just be a setting or you may need the battery movement replaced. I hope this helps you!
Sep 18, 2011 | Bulova Watches
Touch function is not working
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
Jun 30, 2010 | Tissot T-Touch T33759851
Can't figure out how to set day and date and remove back cover to replace battery
Replacing the battery is best left to a watch shop. It can be troublesome removing and replacing watch backs, particularly if they are sealed against water.
While you are in the shop, ask for advice on setting your watch.
Feb 13, 2010 | Watches
My watch no longer makes sound. The alarm and tone setting are on. New battery as well. Is it time for a new watch?
Probably you changed the battery in your watch. While doing that the coil spring got lost, so, there is nothing to transmit the sound impulses to the sound membrane. In this case you need professional help from watchmaker. The other cause can be battery on low level. Replace it.
Rate me, plz.
Jan 27, 2010 | Fossil Watches
Setting watch after battery replacement unable to set watch
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Make it as big as you need.
Hope this tip helps
R/
David
Dec 26, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
How do I rest my Casio PAG-40 after I replaced the batteries?
You need to shortcut AC point and battery. Take tweezers and touch AC and battery (+) simultaneously. Use an eyeglass to find AC point. It is marked on the movement with letters AC.
Here is the link for easy watch setting:
Rate me, please.
Apr 04, 2009 | Casio Watches
Replace battery on a casio gshock.
good morning ! you need to short the reset poin on the bord of your watch after that you see the digit will apear on LCD then start to set the time use the setting button to set the time date and day ! thank you ! god bless !
Dec 16, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
La Crosse Radio Controlled Watch Logo
233 people viewed this question
Top La Crosse Watches Experts
Thomas Perkins
Thomas Perkins
Ngoro
Ngoro
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
