Question about Maytag Dishwashers
The spring popped off my mayday dishwasher door. I can't figure out where it goes to put it back.
  • 139 Answers
Look at the other spring ..their is 2 springs ..they hook to the bottom rail of the D/W let me know an good luck P/S remove the bottom cover plate to see the springs they are located on the left and right side /joe/
Posted on Aug 29, 2010
How do I repair the spring that holds dishwasher door?
The door spring can be seen on the side of the frame just below the bottom of the door. If the spring has just popped off you can put it back easily when the door is open. If the spring has become weak, you can get a new one from an appliance parts store or online.
Jun 10, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Broken door spring
This should not be hard to replace. It would have helped if you had provided the model number of the dishwasher.
You need to buy a replacement spring (best to get the pair) which looks like this item.
BAUMATIC DISHWASHER TG5 DOOR SPRING for BDS461SS
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
Aug 07, 2014 | Baumatic Dishwashers
Philips 7 inch portable DVD player metal spring that allows the door for the DVD to prop up
If someone knows how to fix the spring please let us know. The door came off and the spring popped out but i dont know where the spring goes for the door to pop back open. The open button is NOT what is wrong. Its just the spring that goes in crack on top part of opening where the door is. Tried several things
Feb 13, 2012 | Philips PD700 7 in. Portable DVD Player
The spring came out of the handel and can put it back. how do i fix it?
Dishwashers come with two springs that work to counter balance the door. To reattach it, you will need to remove the panel below the door. Once you get that removed, you can see the side where the spring is still attached to figure out where to attach the one that came off. Some time the spring comes off because it is broken, and you will need to order a new one. Replacements can be found at an appliance supply or online such as repairclinic.com or apwagner.com. Hope this helps you.
Jan 07, 2011 | Dishwashers
The spring on the fuel door (2008 Pathfinder) has popped off and I cannot figure out how to put it back on correctly-even bought a replacement from the Nissan dealer and it doesnt work either-the amazing...
these springs are a bare to install. i take the door off the truck to replace the spring aka install it back. its a pain in the a** to install those. take the door off the vehicle which is attached with 2 bolts (8mm socket or phillips head screwdiver) and re-install spring on the bench. remember bare to install.good luck.
Jan 01, 2011 | 2008 Nissan Pathfinder
The spring came off the door. how do you put it back on it was on the side of the dishwasher.when you open it just flops down find the spring on the floor.do you have picture of where it goes
Remove the bottom toekick panel from the front of the dishwasher.
Look just inside and you will see spring mounting holes on the bottom support frame.
The spring goes from a hole to the hole in the lower door hinge.
If I had a model number I could be more specific.
Sep 14, 2010 | Maytag Dishwashers
Same problem
Spring is probably to the door or to the frame. This is usually what gives the tension for the door to snap back in place. There will be a series of holes on the bottom of the frame where the spring locks in. Remove the kick plate and shine with a flashlight to see where the other side is and put it in the same hole.
Jul 12, 2009 | Kenmore 15762 Dishwasher
Portable Dishwasher Faucet Adapter Comes Apart
I'm glad to hear that solved the problem. I hope the new adapter comes quickly.
Jun 02, 2009 | Danby DDW1805W Designer Series...
Door noise
Common issue with this dishwasher. Easy fix though!! KitchenAid uses a nylon string that connects the hinges to the springs located along the bottom edges of the dishwasher. I had to pull mine out to perform this service. The nylon string seems to dry out and vibrates as the door opens and closes. All that needs to be done is put some Vaseline or other appropriate lubrication all over the nylon string. Especially where it passes through the roller and stationary guide. That will take care of any squeeking or grinding when opening or closing the door. Be careful as your door will now open just like it did when it was new. Now if I can only figure out how to keep my door from popping open during wash cycles!!!
Apr 02, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
The little spring fell off the water door, how to get it back in?
if you can't get the spring back it, put a piece of clear packaging tape folded over on itself on the opening edge of the door, that way you can grab it to open it and it's not obvious.
Nov 09, 2007 | Bemis Whole House Digital Humidifier ED11...
Dishwashers Logo
63 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
