Question about Thorens TD-190 Turntable
The shell is not parallel to the disc surface
    Champion:
  • Thorens Expert
  • 271 Answers
Hi, contact me directly and I will send you the service manual. That tells you how to rectify the problem you have. John. styluscity@gmail.com
Posted on Nov 27, 2011
Timming set up on a chrysler 2.5Litre L4 Tubo motor
marks on crank and distributor shaft face each other and the two cam marks are parallel to valve cover surface on head, with flat surface on distributor body straight paralle with engine
Sep 04, 2014 | 1989 Chrysler LeBaron
How to peel a boiled egg
While it is still hot/warm, put it in cold water, to separate the shell from the egg membrane. Then tap the egg on a hard surface, to break the shell all around. Then peel the egg ... and EAT !
Mar 15, 2014 | Computers & Internet
DVD Player will not power on. Power Indicator Light flashes repeatedly.
Plug out the device,Open the outer shell or strip the outer shell take a hair dryer heat up the board slightly until it feels slightly warm then plug in and switch on and remove disc.Then put outer shell back and fasten screws that where removed.
Jan 06, 2014 | Sony DVP-CX860 Multi-disc DVD Player
What is the formula for getting the surface area of a trapezoidal prism?
Surface area of any prism is the sum of the areas of the sides
A trapezium is A = h(a + b)/2
h is the perpendicular height, a and b are the parallel sides
Aug 10, 2011 | Encore Math Advantage Algebra II and...
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
Hey!My father bought a wii for me and in two days when i put the disc in,it wont take it!Even if it does the screen would turn black and if i press the eject button it makes a noise and wont spit it...
You will need to open it and mess around with the disc drive. You can remove the wii shell and still play on it so I suggest you remove the shell then try inserting a disc and you will see exactly which parts are stopping you. I've got a feeling its the little white piece that goes ontop of a disc as its put in sometimes they will fall out of place simple fix.
Dec 03, 2010 | Video Game Consoles & Games
How do I remove the rotor on my 1995 dodge 2500 4x4? My problem in the center cap holding it.
Brake Disc (Rotor) REMOVAL & INSTALLATION
  1. Raise and safely support the front of the truck with jackstands. Remove the front wheel.
  2. Remove the caliper assembly and support it to the frame with a piece of wire without disconnecting the brake fluid hose.
  3. Remove the hub and rotor assembly.
  4. Install the rotor in the reverse order of removal, and adjust the wheel bearing as outlined in Section 1.
INSPECTION If the rotor is deeply scarred or has shallow cracks, it may be refinished on a disc brake rotor lathe. Also, if the lateral run-out exceeds 0.010 in. (0.25mm) within a 6 in. (152mm) radius when measured with a dial indicator, with the stylus 1 in. (25mm) in from the edge of the rotor, the rotor should be refinished or replaced. A maximum of 0.020 in. (0.5mm) of material may be removed equally from each friction surface of the rotor. If the damage cannot be corrected when the rotor has been machined to the minimum thickness shown on the rotor, it should be replaced. The finished braking surfaces of the rotor must be parallel within 0.007 in. (0.178mm) and lateral run-out must not be more than 0.003 in. (0.076mm) on the inboard surface in a 5 in. (127mm) radius. Fig. 1: Use a dial indicator and micrometer to check the rotor for run-out and thickness 88479g83.gif
Fig. 2: A correct final rotor finish 88479g84.gif
Fig. 3: Location of the rotor minimum thickness marking 88479g91.gif
Fig. 4: Exploded view of a rotor mounting to the hub — 4WD Dakota models shown 88479g90.gif
Sep 03, 2010 | 1995 Dodge Ram 2500
2043NW simple stand removal?
First, lay your monitor on a flat surface, with the screen facing down, and the stand base oriented towards you. Then, just pull the stand off. Make sure your pulling force is parallel to the flat surface.
Good luck.
Mar 04, 2010 | Samsung Computers & Internet
HP laserjet 4L parallel to usb vista Jumbled font on test page
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
Feb 21, 2009 | HP LaserJet 4L Printer
Thorens TD-190 Turntable Logo
70 people viewed this question
Top Thorens Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Thorens Audio Player and Recorder Expert? Answer questions, earn points and help others
