Question about Dryers
Dryer will not start but power is good. Model fdec647rfs1
    Genius:
  • 1,073 Answers
Check the thermal fuse on the inside back wall to the right of the element housing if no contunity replace it and check the dryer vent for an obstruction befor turning it back on
Posted on May 08, 2008
I have voltage to dryer, door switch checks good, start switch checks good, but dryer will not start. What can I check next?
Check the continuity of the thermal fuse located on the blower housing. This thermal fuse is wired in series with the motor and once blown, power to the motor is terminated and the dryer will not start. Also the power to the heating circuit is activated through the motor centrifugal switch. The dryer will therefore not heat once the motor cannot run.
Disconnect power then access the thermal fuse on blower housing.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
You can bypass the thermal fuse for troubleshooting purposes by disconnecting the wires and connecting them together. Insulate the connection properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
Let us know if you need further advice but indicate the exact model number of the dryer.
Jan 28, 2011 | Kenmore 62622 Electric Dryer
Gas Dryer (model#110.74972300) won't start. Power suplly is good but machine won't power up when set & start button is released. What's wrong?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 17, 2010 | Kenmore Dryers
DRYER HAS LIGHTS BUT WILL NOT POWER ON, WHY?
If you have 220 Volts going to the dryer then most likely Its the Thermal Fuse
Part # 3390719 On this Model the Thermal Fuse is located in the front of the
Dryer not the back. Good Luck
May 15, 2010 | Maytag MEDB400VQ Dryer
Kenmore dryer dryer model 110.67042600. Won't start. Has power
Check your receptacle to make sure that you have 220v, with 110v on each of 2 legs. The dryer operates some things off of one hot lead, and some off of the other. Your motor circuit sounds like it's on the other.
If the receptacle checks good, check your wiring connections at the terminal strip in the back of the machine wher the cord connects.
Best regards,
--W/D--
Aug 20, 2009 | Dryers
Dryer does not start. I got a power tester(cheep one) and am showing only 110 volts. The model is LER7648PQo. Is there a fuse or something in this dryer?
this dryer is a 220 v model check voltage again across both hot legs check breakers and plug
hope this helped
good luck
Jul 11, 2009 | Dryers
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
Frigidaire dryer overheating
the other tstat is on front of blower housing..lift top remove screws at top of front panel from inside remove switch wires front lifts off ..be sure to ck vent first most dryers have thermal fuses that will blow if overheating does occur since yours seems to be working i would suspect vent first..if your concerned about dryer being hot to touch along top rear this is normal heating element is located just below console at rear
Nov 13, 2008 | Dryers
I have a fridgidaire dryer model number FDEC647RFS1, I just taken it apart because of squeeking and a bit of noise. On the door the seal that goes around the drum is burnt and worn out can I replace, it...
I attempted to locate an answer to resolve the issue for you, but your model number came back as invalid. Please recheck your model number, and follow the link that I provided. This will allow you to view exploded diagrams and provide parts images, cost, and shipping details.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Dryers Logo
108 people viewed this question
Top Dryers Experts
