Question about Aiwa PX-E860 Turntable
How do i connect it to a single inputamplifier
    Problem Solver:
  • 10 Answers
I believe you need to go and purchase a single STEREO RCA plug from Radio Shack, Walmart or just about anyone that sells accesories.
Posted on Aug 29, 2010
How do i connect this single phase
three wire, or four wire? are you talking about connecting pigtail to oven? more info, or a photo
Apr 17, 2015 | Ovens
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
How do I switch the wiring for a Garland Model S 686 -2 Stove from Single Phase to 3 Phase?
If the oven is a three phase oven currently wired on single phase there will be three active terminals at the terminal block. There will be links or bridges which connect the single phase to each of these active terminals. Remove these links and connect each phase to each terminal.
Feb 24, 2011 | Garland S686 Electric Kitchen Range
How can i get single phase power from my 3 phase generator
I have not wire this myself
Wiki says under heading of single-phase:
http://en.wikipedia.org/wiki/Three-phase_electric_power
Single-phase loads may be connected to a three-phase system in two ways. A load may be connected across two of the three phase conductors or a load can be connected from a live phase conductor to the system neutral. Single-phase loads should be distributed evenly between the phases of the three-phase system for efficient use of the supply transformer and supply conductors. Where the line-to-neutral voltage is a standard utilization voltage (for example in a 230 V/400 V system), individual single-phase utility customers or loads may each be connected to a different phase of the supply. Where the line-to-neutral voltage is not a common utilization voltage, for example in a 347/600 V system, single-phase loads must be supplied by individual step-down transformers.
So it sounds like you take 2 legs of the 3-phase.
or
Take one leg of the 3-phase and connect to neutral ... neutral could be a ground rod.
I would put a meter on that circuit before hooking up my power saw.
Nov 17, 2010 | Electrical Supplies
How do I connect multiple (two or more) 3 phase ac power sources (from wind turbine alternators) to a single 3 phase junction to power one device?
what did you mean by single 3 phase? single phase motor have two wire output 110-110, 3 phase gen have 3 wires 110-110-110. if only two wires here ,this is single phase, all appliances are only single phase so you can connect it here, except some 3 phase motor or dynamo. the ac current has no polarity so you can connect to it all kinds of load depends upon the amperage of of your turbine generators
Jul 22, 2010 | Kitchen Ranges
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
We have a Carrier mini split AC that we are wiring on a portable office that will be going to a foreign country, the Carrier #38QG24-H. This unit's voltage specifications is 200-240volts, single phase, 50...
please 200- 240 volts is a standard for all and for the breaker is depending of the country if 120 v single phase you will install as usa if 220 v single also you can connect you breaker but the problem is some countries are not 50 hz comfirm the unit is 50/60 hz.
Sep 24, 2009 | Heating & Cooling
Whenever i connect my cam i'm asked for VGA single drivers
plz check your camra wire...hen connect to pc..
thanks for asking
May 28, 2009 | Philips SPC610NC Webcam
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
Feb 19, 2008 | Sony STR-DE575 Receiver
Aiwa PX-E860 Turntable Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
