Question about Dryers
Maytag dryer model SDE305DAYW drum will heat but not turn. Belt is not broken/
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
Musy clarify problem with maytag dryer. heat is working fine but drum stopped turning is it possibly a belt or something got stuck? i can turn drum by hand
You've almost assuredly got a broken belt. There are so many different ways of disassembling various makes and models of dryers, there is no 'one size fits all' instruction to guide you through it.
Mar 17, 2013 | Maytag Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
My maytag legacy dryer SDE305DAYW has a very loud squeeking noise when I start the dryer. After a minute or 2 it stops making the noise. Is this the belt?
While I would suspect the belt also, it could also be the drum bearing since they both could have the same symptoms. Suggest you try to turn the drum by hand and see if you can hear it then.
Aug 13, 2011 | Dryers
In my Maytag dryer model SDE305DAYW the heating element works; however, the tumble drum stopped moving. What's wrong?
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Dec 15, 2010 | Maytag HYE3657A Electric Dryer
I need help replacing maytag dryer belt model no.sde305dayw . I am having a problem getting around the pulley maytag dryer
The Link below will show you the configuration for all dryers. Choose the one that looks most like yours keeping in mind that some dryers are made under several different names: Good Luck
Belt Configuration
Nov 12, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Drum stopped turning
99% of the time it's the belt.
Pull the top off the dryer. Typically a couple of screws in the back and then slide the whole top towards the front of the dryer, an lifting from the front edge open it up like a chest. Check out the drum. You should see a broken belt or no belt.
Sep 18, 2008 | Maytag Dryers
Dryers Logo
187 people viewed this question
Top Dryers Experts
