Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
THE VERTICAL AND HORIZONTAL COLORS DO NOT LINE UP.IT KIND OF LOOKS LIKE THE PICTURE IS IN 3D.
  • 51 Answers
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=esk4nYZKFcg
Posted on Aug 30, 2010
How do you fix white vertical lines on Vizio tv.
Any horizontal or vertical lines on a LCD pane, 90% the chance that is a defective LCD panel.
Aug 01, 2017 | Vizio Televison & Video
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Horizontal and vertical lines themselves are off skew. can you adjust these convergence ines. everything else color ok
    No,this tv 100% have convergence problems,it dead.Any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
    Nov 22, 2010 | Mitsubishi WS48511 48" Rear Projection...
    Thats caused by failed convergence ICs and feed resistors. You can get the JVC repair kit called the AV48WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with repair instructions.
    Sep 12, 2010 | JVC AV-48WP74 48" Rear Projection...
    Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
    hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
    in your case i have 2 posibble answers.
    1) negative image
    tv turns on and shots down in 2sec
    flashing pixels on screen
    dark image
    has sound but no video
    screen goes black and then return to normal picture
    vertical color lines on screen no video
    vertical color lines with video
    vertical bars on screen
    horizontal lines on the image
    picture goes red after while
    IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
    2) just left part of screen working
    just right part of the screen is working
    vertical and horizontal lines on screen
    part of screen not working
    some functions not working
    no video but has sound
    functions not working at all
    IT COULD BE (LOGIC CONTROL BOARD)
    TErry HerreRA
    Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
    Picture in 3d without the 3d glasses
    Replace 2 convergence chips, will start with stk ###-###
    Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Pictures looks 3D-ish with small horizontal lines
    Projection TV sets have several common problems listed below.
    Problem #1) Convergence
    Symptoms:
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted
    • No Audio/Video - makes a chirping sound.
    Example Photo:
    Problem #2 CRT Fluid has clouded over.
    Symptoms
    • Dull Video, Washed out
    • White/Bright looking video
    • Halos around objects
    • Red/Orange looking
    Example Photo:
    You can see more examples and find a fix here...
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
    JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
    18 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
