Question about Coleman Powermate 27 Gallon Air Compressor
Air from compressor is WAY TOO HOT! Model #cl0502710. Spray gun gets too hot to handle in 5-10 minutes.
    Problem Solver:
  • 10 Answers
First check the condition of your air filter. Clean or replace as necessary.
Second time how long it takes for the compressor to build from 0-125 psi. If you have the 15gallon tank and it takes more than 3 or 4 min to build up then you have valve problems. If you have the 27 gallon tank it shouldn't take more than 7 min to build up.
If your pump up times are ok then you need to look at the duty cycle. Compressors such as yours should not be on more than 50% of the time. So if you use the compressor for 2 hours of work it should not be pumping for more than 1 hour of the time.
If your pump is working more than 50% or pumping continuously then you need a bigger compressor for your tasks.
The only other factor to consider is the room temperature. If the room where the compressor is is too hot it only magnifies the problem.
Hope that helps
under_psi
Posted on Aug 30, 2010
  • zlongi Sep 02, 2010
    I have disassembled and cleaned the pressure switch, air valves, etc. no clogs, all in good repair. This assembly will get too hot to touch in 5-10 minutes of use. The hose will get to hot to touch in 15-20 minutes of use. The tank itself will get warm. I believe the only place that could generate this heat is the pump piston, part #048-0774. Does anyone believe replacing this part will solve the heat problem?
Karcher b202 can’t get spray gun off the handle - it has been on a long time.
Hot water, not boiling, pour over the joint and then try. I take it the joint is the standard push in type. When re-fitting, a smear of grease around the joint would not do any harm.
Jun 17, 2018 | Karcher Garden
The handle of kitchen faucet model# 87435 does not come off once when plastic emblem and screw are removed.
its probably seized on, you should spray wd40 all over it & wiggle it about up & down & side to side till it frees up, or tap it gently with a rubber mallet.
May 02, 2015 | Moen Plumbing
Overheating
Hi Jan,
I guess its the compressor or air turbine that cuts out in hot weather; they have high temperature cut outs to protect the motor. Maybe try a larger unit that's not working so hard. Best solution is to use a small airless sprayer because it will spray much faster and you will have less overspray.
Jan 18, 2014 | Air Tools & Compressors
My check valve hose gets very hot, I saw a question, what is meant by regulated pressure?
  1. The regulated pressure is at the output of the pressure regulator i/e the air pressure being delivered to the air tool or spray gun.
  2. This can be set from just a few PSI up to about 180 PSI (on my Porter Cable unit).
Nov 12, 2013 | Porter Cable C2002 150 Psi 6 Gal...
If air supply in mask hooked up can sprayer gun work correctly
you should put an inline air flow valve in the line for the mask you can put a T connector on the end of the hose so both the spray gun and mask can use the air line at the same time. It will work well if the compressor is large enough to handle the CFM of both the gun and the mask
Apr 04, 2013 | DeVilbiss MPV-625 Air Vizor Air Supplied...
Fix or Replace an old Campbell Hausfeld Air Compressor model MT30002
Usually, hot air indicates leaking valves or gasket within the pump or overworking (duty cycle). Most likely parts are not available but would be interesting to open the pump and examine parts. May just need cleaning/removing or carbon deposits, cracked reed valve or worn seat. Easy to repair. Remove the head very carefully marking all parts for easy re-install. Make gaskets using auto style gasket material of same thickness. Make any broken reed valves out of feeler gauge material of similar thickness. Any compressor can be made to work tankless but why not have a tank to store a bit of extra air and allow the air to cool a bit and drop out the water into the tank rather than just push it straight thru to the sprayer. Tankless compressor are mostly used for sprayguns or other tools that allow the air to pass thru so that the compressor will not load and heat up. That could be one reason that your compessor is getting hot. You spraygun should be allowing the extra air to pass thru and not load the compressor. Try adjusting the pressure setting on the compressor to the lowest setting allowing most of the air to bypass, then slowly turn up the pressure till spray gun just works as needed. If you are allowing the compressor to work at full pressure and only using say 25psi to paint, you are wasteing energy because the compressor cannot rest. On a tank type compressor, the compressor will rest when shut off pressure is reached. You can paint with tank or tankless, should be no difference, depends more on the spraygun. Good luck
Jun 10, 2012 | Air Tools & Compressors
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
A/c is blowing hot air
Hi
Wel I am not a mechanic or anything, but i haev had some experience with aircons. The one problem might be that there is a leak in the pipes. 9 out of ten times the leak is where the various pipes join. you can simply take a spaner and tighten them otherwise the leak maybe where the compressor is. if the pipes were blocked then it will not blow any cold air and you said it did blow cold air for a while. the way to find a leak is take soap water in a spray gun and spray the soap water in on the pipes and joints, this should blow a bubble where the leak is. however this can only work if you have gas in the compressor. so fill in more aircon gas first.
hope i am right.
Thanx
Sep 21, 2009 | Chevrolet Cars & Trucks
Rv type,compressor stalls after runing about 5 minutes and will not restart until about 15 minutes later
That cover is not hard to remove. Remove it and check for obstacles first, while it is off :>) I had one do that as it had about a pound of dirt dober nest on the shaft. If that's not it, cut it on and when it stops, cut the power first, and then check to see how hot the compressor is. If it's real hot, try recharging.
Jun 28, 2009 | Coleman Mach 15 Air Conditioner
Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Apr 18, 2009 | Air Tools & Compressors
Coleman Powermate 27 Gallon Air Compressor Logo
200 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
