Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Should the fuel filter have gas in it while running - Craftman lawn tractor - 917.271024
  • 454 Answers
Yes, fuel system is gravity fed. If there is fuel in the tank, there should be fuel in the filter.
Posted on Aug 29, 2010
My craftman lawn tractor run for a while then stalls . the gas filter is empty when it stalls
Sounds like your fuel bowel is dirty or your fuel jet it the bolt that holds the fuel bowel on is plugged.
Take the bowel off and clean it real good and also blow the jets that are in the bolt that you took off . Carburetor cleaner would also be good as well. i also had a mower the tube in the gas tank was dirty on the end where the gas is sucked in I took the tank off and cleaned the tube and put clean gas it the tank. Away she went.
Oct 07, 2014 | Garden
the newer fuel has been giving problems to the rubber seal for the needle and seat in the carb so what happens is the carb over fills with gas and then flows into the intake and crankcase then when in the cylinder it hydrolocks not letting the engine turn over change the needle and seat in the carb change the oil add a shut off valve on the fuel line and shut it off when not in use and if storing for more than a few days run the carb out of gas by shutting the shut off valve and let it run out of gas in the carb this will reduce it happening again
Jul 10, 2012 | Garden
My craftman 31c707 lawn tractor keeps on dying for no reason when im cutting my grass
Perhaps the fuel bowl float is sticking and running out of fuel dies fills back up then runs and dies again take off bowl clean it and the float replace it if necessary
Sep 01, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 15.5 HP, Craftman lawn tractor. I'm having problem with it staying running. It will run just find for 20-30 minutes and then stop abruptly. I have changed the spark plug, oil, cleaned the air...
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 29, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftman 17 hp riding mower. It will start and run but Then it will die like it isnt getting gas. Replaced the fuel filter and spark plug.i can let it idle for a few minutes and it seems fine. I...
Remove the bottom bowl of the carberator and replace the needle-valve and float - cleaning this area as you do so.  Sounds like the float has a hole in it or the needle valve in the carb is sticking.  Use some fuel stabilizer prior to storing for winter next time, if not the old gas turns to shellac and makes things stick.
Jun 12, 2010 | Garden
I have an 18.5 Intek Craftman Tractor. The battery
pull the plug out and crank it over....if it's been sitting, there's liquid fuel in the cylinder...can't compress liquid...drain the carb too...use fresh fuel...
Apr 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Craftman 11 lawn mower...wont start have checked the plugs and it has spark and the carb works fine but still does not run...please help
Hi..my name is Keith..and if you have sparkand it wont start..i would suspect old gas..lawn mowers are very sensitive to gasoline..and it likes fresh gas..but if you do have gas in it that is more than a month old..it needs to be drained and not mixed with fresh gas..but im just going on what you are saying about having spark and the carb is working fine..i hope this has helped..if not please write me back
Jul 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
158 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
