Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking Green Light on Mitsubishi DLP 52525
I have had a Mitsubishi DLP 52525 for 2+ years now and recently the green timer light started to rapidly blink when the unit was turned on and it continued to blink without the picture coming on. After discconnecting the power and then using the system reset button, the problem remained. I swapped out the lamp and the tv worked for about a day and now the same problem is occurring. I have hit the system reset button but to no avail. There is nothing in the manual that deals with what is indicated by a constant blinking green timer led. Looking for suggestions. Blinking green light. TV will not turn on. Lamp replaced approximately 2 months ago. i have a blinking green light and the tv will not reset. I just had the tv picked up by the service company. It is still under warranty as I purchased the extended warranty for five years. If it can't be fixed I wonder how they will compensate me?
  • Anonymous Aug 28, 2008
    I have the same TV and the same problem.
  • stevetbyrd Aug 30, 2008
    I too have the green blinking light problem. I've hit the system reset and nothing happens.This light was preceded by a blinking red light.
  • Mitsubishi Master
  • 8,617 Answers
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
http://servicemanuals.vstore.ca/
Posted on May 08, 2008
3 Suggested Answers
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
  • 18 Answers
REPLACED CAPACITORS ON POWER SOPPLY -- DM BOARD AND FMT BOARD ..
OOOH THEY LOOK GOOD .DON'T THINK TO MUCH....REPLACED.
1000MF X16 V. 8 TOTAL.....
Posted on Sep 17, 2008
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Try the ballast that gives power to the lamp,I have the same problem,got a lamp for $109.00 at discount-merchant,thisa is my second problem with this tv in about 3 years,sucks.
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The 52525 is definitely going to either:
1. have the caps on the FMT/DM board replaced (not something I'd recommend you do yourself)
2. have the electrical chassis rebuilt (as sometimes, you can replace the caps and still have the problem).
wait time: 4-8 weeks
cost to rebuild: $400-$500
cost for labor: $200-$400
Oct 13, 2008 | Mitsubishi WD-52627 52" Television
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dec 17, 2007 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
378 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
