Question about Bissell 3920 Bagless Upright Vacuum
My Bissell 3920 motor is making a high pitched noise. I have cleared out pet hair from top to bottom. Cleaned the lower filter and replaced the upper filter. I Checked for blockage in the hoses and found none. The filter indicator goes green when I turn it on, but the straining motor noise persists.
  • wmtem Aug 29, 2010
    Is replacing motor bearings/motor fan an easy task? I can't find motor bearings or fan under parts on this website to price. Can you estimate what each item costs?
    Thanks.
  • 944 Answers
The reason for the high sound is
motor bearings has gone bad.
Some times defective motor fan will also cause this loud noise.
So you have replace the motor bearing or fan accordingly.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Aug 29, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Aug 30, 2010
    You can replace the motor by yourself.If you are good mechanic.
    But the bearings and fan can be only replaced in service center..
    Motor bearing cost 3 pounds.
    Motor fan cost from 17 pounds.This one looks palm size fan.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
The filters are new, the belt is new, I cleaned the hoses but my Bissel seems to blow the dirt out the back onto my feet help
There is probably a clog somewhere. Start by checking the tube where the air is sucked into the vacuum by the brushroll
Mar 15, 2014 | Bissell 3920 Cyclonic Pet Hair Eraser...
Access motor on Bissell 3920 Pet Hair Eraser?
Hey Janalynn, you should contact one of BISSELL's Authorized Service Centers for assistance.
Here's a quick link to locating one of Authorized Service Centers, please click on the following link:
http://www.bissell.com/service-centers/?cid=ccsocial
Feb 01, 2013 | Bissell 3920 Bagless Upright Vacuum
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
HI I have a Bissell Pet Hair Eraser it has a very loud high pitched squeal, I have removed the belt & cleaned it with no effect. Is there something else I cn do? Thanks Joe
The belt may be stretched out and therefore, no good. You can try roughing up the surfaces the belt rides in with some 150 grit sandpaper. That may do the trick
Feb 02, 2011 | Bissell Upright Vacuum - The Pet Hair...
We have a Bissell 3920 with low suction and part loose
Call Bissell at 1-800-237-7691.... press 3 to ask a representative for help... press 1 to find Bissell service centers in your area. You may be able to take it to a local vacuum clean and repair center if Bissell's store is too far from where you are located. That is if it needs to be repaired by a professional.
Jul 22, 2010 | Bissell 3920 Cyclonic Pet Hair Eraser...
Bissell lift off vacuum about 4yrs old. Extremely noisy. OK until before Christmas but getting worse every time it's used. Washable filters washed, HEPA filter replaced. brush bar cleaned of every scrap,...
Sounds like a bad motor bearing. If it is, then you would have to replace it. Could be the brush roll, did you check the ends to make sure they turn easily?
Apr 30, 2008 | Vacuums
High pitch
Sounds like you have a clog. Make sure the filters are clean, replace if it has been more then a year, check the inlet down by the brush roll, your clog maybe there.
Dec 24, 2007 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Bissell 3920 Bagless Upright Vacuum Logo
667 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
