Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The remote opener reset button goes off and will not work
There is a green reset button o the back of the unit and the green light has to be on in order for the remote to work. Once I reset the green button the green light comes on but will go off after about one minute. When the green light is off, the remote wouldn't work Works with the wired switch even if the light is off.
  • 504 Answers
The green button is not a reset it is the program button.
If you hold the button down for about 20 seconds it will erase all codes. Then, press and release the button - press and hold the button on your remote for about 10 seconds. the next time you press it it should activate the door. Repeat the 2nd step for all additional remotes.
The lock button on the wall control locks out all radio signals for vacations etc.
If the lock has been activated the green led in the wall control will flash - when the lock is deactivated the led stays solid green.
Hope this helps
Posted on Oct 05, 2010
My garage door starts down then goes back and the motor light flashes 10 times. The owner's manual only refers up to 6 flashes.
Richard, what is the make of your GD Opener unit? However, make sure the antena wire on the unit is turned up. 2. sometimes direct sun on the sensors prevent operation from the remote. 3.adjust sensors on both sides making sure the green or red lights are on.4. check the remote battery ensuring red light works when you press the remote button. 5. finally, has on vacation switch on the unit has not been switched on. GL
Dec 01, 2014 | Building Materials
My garage door opener has stopped working. No
There isn't a reset but make sure the trolley isn't jammed against the bolt just in front of the motor unit.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Jun 29, 2009 | Chamberlain 950CB Remote Control
Garage opener not responding with remotes, keyless pad, or wall console. Can hear it click but nothing happens. Green light in opener blinks 5 times. When i reset the green light stays on until i try to...
UNPLUG UNIT TO RESET.
IF IT STILL FLASHES 5 TIMES AND MOVES 6-8 INCHES REPLACE RPM SENSOR.
IF IT STILL FLASHES 5 TIMES AND DOESN'T MOVE REPLACE LOGIC BOARD.
Apr 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage door opener not working
First, check the springs in the actual door to make sure that they are not broke. Since you held the learn button down to reset the opener, you have to reprogram all of your remotes. This button only resets the remotes. It has nothing to do with the rest of the opener. To reset the opener, simply unplug it for a couple of minutes and then plug back in. Pull the handle on the door and see if you can operate the door manually with one hand. If it takes more than 15lbs to move the door, there is a problem with the door balance. If the springs are not broke and the door operates smoothly, the likely cause is the rpm sensor on the opener.
Feb 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
OLDER SEARS GARAGE DOOR OPENER WONT OPEN GREEN LIGHT FLASHING
do you have the sensors at the bottom of the door? if so they might be out of alignment. all you have to do line them up by getting the green light solid. let me know if this helps you.
Dec 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Flashing green light on Sears garage door wall opener HBW0777 1/2
Same problem - The flashing wall button indicates the remotes are locked out. I fixed mine by pushing the green button on the back of the opener. I did nothing else , just left the LED time out.
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
236 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
