Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Broken Impeller - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
    Problem Solver:
  • 15 Answers
INTEXSTORES.COM CARRIES ALL THE PARTS TO FIX YOUR IMPELLER.
Posted on Aug 30, 2010
  • steven
    steven Mar 02, 2014
    Intex does not sell ANY parts for their filter pumps. A Google search for broken impeller will turn up hundreds of irrate customers with the same problem. Intext are a junk product with no after sales parts. Even the intexstores webiste doesn\'t work. Say no more.
I have a ao smith sp 1520 2 hp pool pump. the impeller broke off the shaft. how do i change the broken impeller please
Remove the back of the motor ... you will find there are flats on the shaft. Put your 7/16 or 1/2 open end wrench there and with your other hand, spin off the broken impeller.
Aug 22, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Hi, I have a Triton Power shower, it has worked fine for the last few years but today the water stopped. The pump is still running but nothing is coming out. Would you have any ideas. Thanks, Gary
Hi Gary, Sometimes things like pieces of worn out faucett washers get in the shower head water line and clog things up. The only alternative is to disconnect the plumbing starting from the shower head back to the wall and start removing the pieces of rubber. There could be a problem with the impeller in the power shower pump but again you would have to gain access to the pump impeller and inspect it for damage. An impeller can fail in may ways... most of the time it is either broken blades of a broken hub of the impeller. Other times the housing for the impeller can be broken and water bypasses inside of the pump vs exiting the pump.
Thanks for using FixYa.
Kelly
Jun 03, 2010 | Home
Won't drain
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump, like the occasional stray piece of clothing, and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are broken/missing or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 25, 2009 | Washing Machines
I have an older model Whirlpool washing machine that won't drain
I would check the drain line for kinks and obstructions and then the pump. Remove the hoses from the pump and check for anything clogging it (like the occasional stray piece of clothing) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller will spin freely. If any blades are missing/broken or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Washing Machines
Drain pump makes rattling noise when operating, pump has been clened.
I would look at the pump impeller and make sure there are no broken or missing blades. Hard objects can make it to the pump and cause damage to the pump impeller blades. Also, the impeller must spin freely. If the impeller has broken/missing blades or if the impeller won't spin freely, the pump is defective. Really sorry for your trouble and I hope this helped. Best wishes.
Washer is not draining
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller will spin freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged pump, drain line, or a jammed impeller. Hope this helped and best wishes.
Sep 08, 2009 | Maytag Washing Machines
F21 code
Sep 06, 2009 | Kenmore HE2 Plus Front Load Washer
Washer spins but does not drain
Sep 06, 2009 | Washing Machines
My frigidaire gallery series front load washer had a code F03 what does that mean besides it wont drain the water?
First, make sure the drain hose isn't kinked, clogged, or collapsed anywhere. Then,take the hose off the pump and using a flashlight, look into the suction port, looking for anything clogging the pump and check the impeller blades for any missing or broken blades and that the impeller will move freely. If any impeller blades are missing/broken or if the impeller won't turn freely, the pump will have to be replaced. Hope this helped and best wishes.
Aug 04, 2009 | Washing Machines
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
443 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
