Need to open my Sony Vaio PCG-392L to replace the power adapter. please help. Thanks.
5 Suggested Answers
chris252
  • 84 Answers
SOURCE: DIAGRAM FOR SONY VAIO PCG-k45 (service Manual) free download
i might tell u but only if you tell me how to post questions thks
Posted on Mar 31, 2008
HW_Dude
  • 87 Answers
SOURCE: How Replace CMOS Battery in Sony Vaio VGN-FS742 / PCG-7D2L?
Here is are disassemble instructions for you,
Good Luck
Posted on Jan 11, 2009
  • 19 Answers
SOURCE: Looking for the specification of the Sony Vaio PCG-8K2R
http://esupport.sony.com/US/perl/swu-download.pl?mdl=PCGTR3AP&upd_id=1087&os_id=7
just click and download your driver
Posted on Aug 24, 2009
joecoolvette
  • 5660 Answers
SOURCE: how to replace power jack on sony vaio pcg-k33
Short version?
1.Remove the AC adapter if plugged in, remove the battery.
2.Wear an ESD wrist s-trap, and have it connected to a good ground. Work on a table, have a container with multiple compartments for the screws, and mark where each screw came from. There are as many as 65 screws, and 8 different sizes.
3.Completely disassemble the laptop, down to the bare motherboard in your hand. Remove the LCD screen assembly. No Processor, Cooling Tube, Heatsink, Ram Memory modules, CD/DVD drive, Harddrive, Wireless Antenna module, Keyboard, Nada!
4.Buy a replacement DC Power Jack.
Here is an example of one,
http://powerjack.us/index.php?main_page=advanced_search_result&search_in_description=1&keyword=Sony+Vaio+PCG-K33
5.Use the correct tools.
If you're a really experienced tech, you can use a 30 to 40 Watt soldering iron. No.2 tip. Have a clean damp sponge nearby, to constantly clean the tip.
Make sure the tip is clean and tinned correctly.
Or use a medium priced soldering station.
I advise using soldering wick, (Desoldering Braid), instead of a Desoldering Tool. Works much better.
5.Use the correct soldering procedures.
Linger too long when heating up the solder joint, to remove the DC Power Jack, and you stand the chance of burning the board. (Motherboard)
Also could lift the Circuit Trace right off of the board.
(Circuit Trace may be thought of as a very thin, copper wire on the motherboard. It isn't, but this explanation will do)
Do any of the two errors above, and you can use the motherboard for a Frisbee.
My method for removing the DC Power Jack, is to pull up on one lead at a time. Use constant pressure with my finger, and thumb. (Don't get 'Godzilla' on it. It can break. Everything has it's limits!)
I heat the solder joint for that one lead, and try to pull it up, a little out of the board. Then I move over to another lead, heat it, and pull up slightly on it. Keep moving from lead to lead, until finally they start pulling out.
After the jack is removed, the area needs to be cleaned. I use 90 percent Isopropyl Alcohol, and Q-tips.
CAUTION!!!!
This is HIGHLY FLAMMABLE! Keep it away from that hot soldering iron, and use in a Well ventilated area.
Always immediately return the cap to the bottle, and tighten the cap well.
Have fire precautions ready, just in case an accident happens.
Better Safe, Than Sorry!
The area of solder, around the hole in the board for the jack, may need to be buffed off. (Fine sandpaper in a tight roll, or a fingernail file using the fine side)
All areas that will accept solder need to be clean, and tinned.
Tinned, ...is the area is cleaned, a light spot of flux is touched around the rim of the hole, then solder is applied. The hole's rim then has fresh solder around it, and is ready to accept the DC Power Jack lead.
Be sure you have good solder joints! You may not see a cold solder joint, until you put the laptop back together, and the jack doesn't work. Then you get to take it all back apart, look at your solder joints, and go "OH".
This may help you in disassembling,
http://www.insidemylaptop.com/disassemble-sony-vaio-pcg-k-notebook/
Posted on Oct 19, 2009
Sony VAIO PCG-392L screenwith striped colors
Hook a spare monitor to the video output of the laptop, if picture okay! the LCD panel display is defective and most be replaced. But if symptom is the same on both screens it indicates a bad Video Graphic Card normally built into the motherboard.
Mar 19, 2012 | Sony VAIO PCG-505TR Laptop
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Mar 11, 2012 | Sony Computers & Internet
Vaio pcg-k33 power cuts off unexpectedly. Cooling fans are broken. Need a guide to open laptop and replace cooling fans.
This over heating issue is a common issue for this model of VAIO Computer. You will get a free service or replacement of parts(Battery) from the Sony Service Center. For more information please follow the link below.
Battery Replacement
Hope this will help you. All the best.
Sep 12, 2010 | Sony VAIO PCG-K33 Notebook
Sony vaio pcg-3c1m does not start
recharge your battery or run the laptop while being connected to the AC adapter power
Mar 14, 2010 | Computers & Internet
Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
you can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
please take a rating let me know how much helped you thanks!
May 21, 2009 | Sony VAIO V505DC PC Notebook
Sony vaio pcg-r505el won't turn on
Vista or xp? I'm assuming Vista?
Apr 06, 2009 | Sony VAIO R505EL Notebook
Power adaptors/ travelling/ aptop
Yes, it is a switching power supply meaning that it automatically detects 120v (US) or 240v (EU) voltage. The only thing you might need is an adapter to convert the actual plug in from US to EU standards; they can be picked up for just a few dollars.
Thanks for using fixya and please take a moment to give this solution a rating of fixya. Thanks! :c)
Feb 02, 2009 | Sony VAIO PCG-K35 Notebook
Pcg k45 sony vaio
chek the adapter and female power soket on laptop. if they are ok, clear the bios by reset bottom(there is a small hole under laptop) or removing small battery on mainboard.if the problem not solved ,have to change the mainboard.
Aug 16, 2008 | Sony VAIO K45 Notebook
Help!!!!!!!!!!!!!!
It's probably the power socket on the laptop not the power jack on the AC adapter. You need to open the laptop by removing the casing screws. Then remove the motherboard from the base so a new socket can be soldered on.
Apr 02, 2008 | Sony VAIO PCG-V505EC Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
