Question about Canon MultiPASS F50 All-In-One InkJet Printer
Scanner Error I am recieving a scanner error. The copier will not work either. It was working fine and then the copier would not copy, then I got the scanner error.
    Champion:
  • 258 Answers
What type of ERROR? Without knowing type of error one cannot help u my friend.
Posted on Jul 15, 2008
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Printer will copy and print just fine, but it will not scan from the printer or from the computer.
did you recieved error message example 1-2006. If your unable to scan its more On the software and driver issue of you printer., you need to call kodak to properly installed your software and drivers toll free 1 800 421 6699 ext 05.
Nov 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp laserjet 3380 - MS Vista - scanner error, copying is ok
clear glass, replace ribbon scanner cable if no result - replace scanner
Aug 24, 2009 | HP LaserJet 3380 All-In-One Printer
Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
May 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Mar 15, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
All-in-one printer/scanner not working
did you installed software from the cd that came with it?
windows installe it as a scanner that you can use from Control Panel->scanner and cameras following the wizard...
to use the buttons on the scanner you must install software and configure it
Mar 15, 2009 | Lexmark All-in-One Printer, Scanner &...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error code
The L3 code refers to your scanner not moving. One thing you can check is the scanner lock, which is a clear round dial located under the scanner bed (where you remove your copies from).
I've seen that dial get bumped into lock position when copies are removed from the recieving tray. Alot of times, I'll remove the dial to avoid that problem in the future.
Apr 11, 2008 | Toshiba e-Studio162D Copier
Canon MultiPASS F50 All-In-One InkJet Printer Logo
57 people viewed this question
old marine
old marine
