I have a 20 year old Mitsubishi model CS-26201. Someone unknown to me (we have a vacation rental) programed the parental lock. Help! How do I break the code to unlock. Roland
  • rdwdeng Aug 29, 2010
    This is not a flat panel TV. It obviously is an old CRT type.
    Roland
How do i remove parental code
  • Using your remote press the number "9" and the "QV" buttons at the same time while on the code lock screen.
  • It's that simple.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 31, 2011 | Mitsubishi CS-26201 TV
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
Mitsubishi CS-27305 has unknown parental password lock set. How do I defeat it?
have a tech unsolder the eprom and replace it back,that will configure the password.so that you can enter a new password if you want,good luck
Jul 12, 2009 | Mitsubishi CS-27305 TV
Mitsubishi CS-26201. Can't get clear image on screen
Hopefully you still have the remote.
On Remote, hold the Q.V. button down and press the number 9. That will bypass the lock
Then press the menu button on the remote - go to Advanced features, select Parental Lock - it should sho as on, hold the Q.V. button doown and press the 9 button again, and you will turn the lock off
Dec 31, 2008 | Mitsubishi CS-26201 TV
Mitsubishi Television, Model # CS-26201
I WANT to REMOVE THE MODO ESTéREO AND SAP AND I WANT to PUT IT since NORMAL SOLAMNETE it is LISTENED IN ENGLISH AND I WANT ANYTHING MA   To PUT IT IN SPANISH THANK YOU FOR THEIR ATTENTION
Dec 18, 2008 | Mitsubishi CS-26201 TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Universal Code for Mitsubishi CS-26201TV
After searching the web for hours this is the one that worked for me , if you have the same remote i have it should work for you too.
Code # 10150
May 09, 2008 | Mitsubishi CS-26201 TV
Parental control code lock tv
I am not sure if this works for your model, but if you have the original remote, turn the TV on, point the remote at the TV and press the "QV" (quick view) and the "9" buttons at the same time. Let me know if that works.
Sep 01, 2007 | Mitsubishi CS-26201 TV
Tv lock because of parental code
You will need an original remote control, which you can order online. With the original remote, turn the TV on, point the remote at the TV and press the "QV" (quick view) and the "9" buttons at the same time.
Televison & Video Logo
307 people viewed this question
Top Televison & Video Experts
Electro Med Services...
