Question about Kenmore Dryers
I have an older Kenmore 70 Series Dryer, but when I set the timer to dry it doesn't move, it stays in the same place. Any ideas?
  • tarmule Aug 30, 2010
    Yes, If i shut it off by hand it turns off
  • Kenmore Master
  • 2,290 Answers
Do you have heat in the dryer?is it on time dry or auto dry?when the heat shuts down then the timer will advance in auto, when the heat starts again the timer stops.let me know if you have heat or not and send the model next time,will start with 110. or something like that and eight numbers after the dot
Posted on Aug 29, 2010
Testimonial: "very helpful"
  • 1 more comment
  • tarmule Aug 29, 2010
    The dryer does have heat and the timer does not work on auto or timed dry. The model number is 110.66712694.
  • Sal DeAngelo Aug 29, 2010
    if it's doing this on time and auto i'd have to say the timer is bad,if everything is running normal except for the timer not counting down it sounds like the clock in the timer is bad,the part number is 3976577 and it's around 90 bucks.tell me is everything running good except the timer isn't moving and can you hear the clock ticking in the timer,one more thing if you turn the timer by hand to off does it shut down
  • Sal DeAngelo Aug 31, 2010
    you have a bad timer,change it out and you'll be fine.the part number is 3976577
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Long drying times model #11062712100
Try this and let me know what happens.
TIP OF THE DAY
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Feb 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
Jun 04, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore 70 series,does not dry
Check the vent pathway. Perhaps the theromstat is sensing high temp due to restricted air flow and kicking off.
Oct 16, 2007 | Kenmore 93042 Gas Dryer
Dryers Logo
238 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
