Question about Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
Problem with Sta Rite Max-E-Therm High Effiency - Gas Heater - 400,000 BTU Model SR400NA. When the heater turns on, the display shows a pool temperature of 109-110, which means I cannot get the heater to blow. The water temp is actually 75 degrees so the unit is malfunctioning. The unit is only four years old. What needs to be replaced?
  • 640 Answers
Here is copy of the users manual for these pool heaters. Try the troubleshooting guide. You might be able to solve the problem.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Dec 07, 2010
    Problem Solver:
  • 5 Answers
I think you shuld replace your temp swich is next to the outlet/inlet piping
Posted on Sep 09, 2010
4 Suggested Answers
  • 83 Answers
SOURCE: Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
  • 990 Answers
SOURCE: Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
Posted on May 13, 2010
I have a Sta-Rite Max-E-Therm High Effiency - Propane Heater - 400,000 BTU and the pool pump and heater work fine untim the next morning. The pool pump comes on and the heater does not. The service light...
How old is the heater?
When was the last time it worked correctly?
Does the pool reach the set point? If not, how close does it get?How long will the heater run (hours)?
What model pump are you using?
May 29, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater will not ignite' service light is on?
I suggest that Sta-Rite technical support would be the best ones to help you determine what the problem is. I hope this helps.
Aug 09, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
E01 message when we attempt to turn on pool heater
These pool heaters have a great troubleshooting section in the users manual (link below). Try walking through that step by step. It should help you correct your problem in no time.
Jun 04, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Shows r 5 code when power is turned on. sta-rite
The R5 is a sequence code in the boot up sequence where your error is occuring. There is nothing in the users manual for these pool heaters that explains this error. Your best bet, unfortunately, is going to be to call Sta Rite. Here is their customer service number: 1-800-831-7133
May 08, 2010 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
382 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
