It is neither beng shown in my computer nor it is working . vista is sking for a fresh driver download & installation as there is a problem in the registry.
  • 808 Answers
Yes its looking like the problem in ur registry so do a registry repair scan with Intel software partner Reg In Out registry cleaner it will solve ur problem
Posted on Aug 30, 2010
Sony Vaio laptop vgn-cr520e...fresh install of Vista Home Premium 64 bit edition...getting battery installation warning "the battery might not be installed correctly or may be incompatible with with...
I used to have the same problem, the chipset driver none for vista 64 > system will assume Intel v.8 core driver XP64bit as the driver.
two solution that comes up to me :
1.downgrade to XP32bit most feature eg.webcam works fine (xp64bit = motion eye app wont go)
2.Upgrade to win7 ultimate 32/64bit both works (64bit some missmatch driver found on IDE/ATA Controller >> always goes to standard dual channel)
Cheers
akee_akee@live.com
Aug 17, 2011 | Computers & Internet
Install cd for web cam vx-6000
Hello. You can download the software for your VX-6000 by accessing this WEBSITE.
Note that the driver above is available only for Windows XP.
Enter the code shown and click on "Download This Driver for Your Device from Open Drivers" then download the file. Save it to your computer, run and install it properly!
For Vista, you can try this WEBSITE. (Also enter the code shown and download the software)
I hope it works!
If you have any other questions, please leave a reply!
Thank you for using FixYa!
May 28, 2011 | Microsoft LifeCam VX-6000 (68C-00001)...
My camera it not support for win 7, 32bit, please tell me why not thanks
The Computer model VGNFJ270/B was shipped with XP OS and Sony had provided an upgrade path to Windows Vista. Sony does not recommend installing any other OS in the computer, as they are the OEM manufacturer of the product, they will know which features may fail to work with a new environment.
The drivers are tested to work with XP and Vista environment.
However, as we have seem that Vista drivers had generally worked with Windows 7 OS, I would suggest that you try installing the Vista Drivers for the camera and check if it helps:
Install VAIO® Camera Capture Utility:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ270B&upd_id=3604&os_id=27
Then, install Sony® Camera Filter Driver Update
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ270B&upd_id=2471&os_id=27
And install VAIO® Camera Utility Update
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNFJ270B&upd_id=2465&os_id=27
Thanks!!!!
Dec 17, 2010 | Sony VAIO VGN-FJ270/B Notebook
How do i wipe laptopt and restart fresh?
You need to have the OS CD to do that. More often than not once the CD is inserted the installation process should in case it doesn't start then you need to change the Boot Sequence and the complete step is mentioned below.
Its Simple you are sure to like it.....Try it Out....Good luck
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation >Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Nov 16, 2010 | Microsoft Windows Vista Ultimate Edition
Sir, i hv a laptop hp Compaq Prasario CQ42 139 TU. I m facing a Problem i can't accsess web cam. I hv installed all the driver. I m loaded frist Vista Home basic but not shown now loded Vista Ultimate but...
Try to uinstall the web cam if installed, and allow the computer to reboot and detect the hardware.
Download the drivers or the web camera from the manufacturer's website.
Aug 03, 2010 | HP Computers & Internet
No sound after installing Windows XP
install your original sound driver. don't install buetooth. sound driver first, bluetooth causing audio failure.
Jun 02, 2009 | Computers & Internet
Drivers problem for win vista ultimate...
Drivers can be download at
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&lang=&product=1136346
Just select the operating system and download drivers.
If you drivers are not listed you can also download drivers for windows Xp which will also work.
May 31, 2009 | Computers & Internet
Installing driver for HP Deskjet 1520 on Acer Aspire with Vista
i recommend an uninstall on the printer software..update the operating system with all known bug fixes, then download a fresh driver set..
Nov 21, 2008 | Office Equipment & Supplies
Bought new computer with vista operating system & our hp psc 2100 all-in-one printer will not work. thanks
Install the drivers built into Vista as shown at HP's website here.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Aug 24, 2008 | Office Equipment & Supplies
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
