Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Rolling into balls
When I am drying sheets and/or blankets; they always turn into ball form. I always have to work with it till dry. It should tumble the item dry without having to return to shake out and tumble again; sometimes three or four times before dry.
  • 487 Answers
There is nothing you can do about this. the disadvantage of sheets and blankets.
Posted on May 08, 2008
Front load washer detergent dispenser is jammed. How to unjam it
It is usually because the detergent has dried in the check ball and spring area of the dispenser.
Unscrew the fitting the inlet tube attaches and takes the spring and ball out. Clean the dispenser area and the ball and spring. Reassemble and it will usually work.
Hope this helps.
Shane
Mar 01, 2011 | LG Washing Machines
Tip
How to extend the life of your front load washer?
hello, i am Marclavoris your guru today with some tips to extending the life of your washer and your dryer. These are just some tips that will help you.
First of all for all of you front load washer users, many times i get many customers who after several uses of their front loaders, they smell mildew and a musty odor. This is due to the front rubber gasket being saturated with water or standing water, to prevent this from happening always wipe the front door gasket down or leave the door crack after usage.
I have notice that people use alot of fabric softener sheets, sometimes the clothes will push the fabric sheets down into the lint filter housing which could eventually cause clogging of lint or the static will cause lint to pile on top of each other accumualting a big ball of lint, which in turn will cause your dryer to take a long time to dry and may blow out a dryer fuse.
on Jan 04, 2010 | Washing Machines
Detergent not sucking at the time of washing.
When the detergent is not sucked by the washing machine it is usually because the detergent has dried in the check ball and spring area of the dispenser.
Hope this helps.
Shane
Feb 20, 2011 | LG WM1812C Front Load Washer
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryer Squeaks
ok your having the begings of a rear bearing problem now let me tell you whats happing if you pull the dryer out and look about at the middle of where the drum is at the back then you will see a silver small rectangle peice in the middle of that is what looks like a small finger with a steel ball under it on the little ledge there should be a little pile of black dust the little finger is making the little ball cut into the back of the rear bearing but the rear bearing is still good now get you a little can of spray lithem grease clean the dust off turn the dryer on and spray that little ball till its coated then every time you hear it squel repeat the proceadure untill one day it wont stop then we will have to change it and on that day you better have some help lol
Mar 31, 2008 | Kenmore 94702 Front Load Stacked Washer /...
Wrinkles!!!!!!!!
This is a frequent complaint with the following known  solutions:
  • You might be drying them too long. back the time down so that the cool down cycle happens right as the clothes are dried.
  • Try smaller loads.
  • You should dry heavy fabrics and light fabrics separately.
  • Fabric softener in the washer may help to prevent wrinkles from forming in the dryer.
Feb 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
89 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
