Question about Fedders A7DH45B2A Dehumidifier
No water output - Fedders A7DH45B2A Dehumidifier
  • Fedders Master
  • 43,501 Answers
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 29, 2010
How do I control the temperature output?
There really is no "control" for the output temperature on a dehumidifier. HERE is a tip that may help explain the temperature output for a dehumidifier.
Aug 14, 2011 | DeLonghi DE500P Dehumidifier
My dehumidifier no longer works. It started with running almost contantly without much water output. Now it just runs without any output. I only run it spring summer and fall. It is located in the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jul 31, 2011 | Haier DM30EAL Dehumidifier
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
How much water to put in the water entering tray
dehumidifier's remove moisture from the air,so you really don't want water anywhere close, the tray in a dehumidifier is to collect water removed from the air. a humidifier is easy, you put a pan of water close to a heat source or moving air
Jan 31, 2010 | Dehumidifiers
Humidifer is not taking out water. Is there a start capacator for the compressor?
This could be one of several things, we are assuming the air is humid. If the fan is not running and the compressor is, replace or repair fan motor. If the compressor is running, the output line from the compressor should be warm, if not you probably have low refrigerant gas, plugged cap tube or a bad compressor. If it is slightly warm check the evaporator portion at the outlet of the cap tube, it should be cold, probably in the 40F range depending on ambient temperature, if not see above.
Goof Luck,
Gilsh
Nov 26, 2009 | Amana D545M Dehumidifier
It collects some water but it also spits water out
The dehumidifier has a non-removable tray under the coils (they look like radiators) that collects and drains the water away. If the tray or drain gets clogged with dirt or slime the water doesn't drain away well. Some water is picked up by the fan and is blown out the vent. Take the covers off the machine and give everything a good cleaning. If you get water on any electrical parts, let the machine dry thoroughly before plugging in.
Nov 12, 2009 | Frigidaire FDL50R1 Dehumidifier
Water tank still gets full when connected to floor drain
Check the fitting where you connect the drain hose to. It may have a plastic seal that must be cleared out in order to use the hose drain. The plastic seal can be easily punched out.
Jun 07, 2008 | Danby DDR600R Silhouette Dehumidifier
Connected Drain Hose - Is not draining, what gives?
Usually all you have to do is to remove any cap on the outlet fitting, attach the hose, & make sure it has a downhill run to the drain or well. Visual inspection should be enough to guarantee no obstructions exist.
Jun 24, 2007 | Haier HDN655E Dehumidifier
Fedders A7DH45B2A Dehumidifier Logo
49 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
Steve
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
