Question about Kenmore Dryers
Dryer takes 2 cycles to dry clothes, felt hot on left vent as you are looking into the dryer. the right side vent was cold.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
The top right side and the right side of the get very hot when drying clothes
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 26, 2015 | Dryers
Does not dry cloths. dryer gets hot,top and sides during drying cycle. it takes 2-3hrs to get cloths dry.
most probable cause of heating yet not drying in a crushed or restricted vent (imagine only inhaling while breathing yet not never exhaling)
Jul 22, 2011 | Kenmore Washing Machines
Dryer doesn't dry (flame cuts out)
279834 is the part number for the 2 coils ( kit ) which mount on the burner . Only 2 screws hold the coil retainer . One coil is opening ( shorting ) after it gets warm . Replaceing both will solve the problem . Easily replaceable .
May 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
ALOT OF MOISTURE LEFT IN DRYER. TAKES 2 OR 3 CYCLES TO DRY
If your clothes are getting hot but are still moist it means the moisture is not being vented properly. Check your vent pipe for blockages. Also check that the length of your vent pipe is not to long (under 8ft).
Jan 04, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Needs 2 drying cycles
I am assuming you are cleaning the lint filter. Check the vent pipe out the back. If it vents into the wall, the piping leading to outside may be plugged. Your washer is spinning the clothes good, right? If the clothes are excessively wet they will take longer to dry also. If its practical, remove the vent hose and let it dry blowing into the room. It may suck but just once for a test.
Mar 06, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
