I have a Samsung laser printer model ML-2510 and paper always jams. It actually does not go through the feeder. You have to manually feed the paper so it goes through. I had it serviced and got fixed but the problem came back just after about 2 weeks. Can you help me on this?
  • 472 Answers
  • You can take the easiest route and use a cotton swab with a mild solvent (Heptane, more commonly sold as Rubber Cement Thinner) and clean with a side-to-side motion, the black pickup roller in the center of the pickup bar. No screwdrivers needed, no dis-assembly of the machine other than the paper tray and single-sheet feeder.
  • My second choice if you don't have the Heptane solvent would have been Fantastik or 409 cleaner or another cleaner with ammonia. It seems to me that the roller picks up paper debris, dust, dirt and other airborne crud creating a slick surface on the roller which can't grab the paper. Just removing the film with a solvent or cleaner should restore the roller surface to the point where it can do its job.
Good Luck!
Posted on Aug 29, 2010
How do I get the paper jam out of the Samsung ml-2510
if it is a whole piece of paper open the toner door and take the toner out and that should give U access to the jammed sheet. If it is just little pieces of paper get as many as possible and them push a piece of card stock through to clear out the rest
Feb 03, 2015 | Samsung ML-2510 Laser Printer
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
The paper starts to feed , then stops. There's no jam.
the problem is paper feed roller their have a dust. clean it properly. and then print again
Jan 07, 2011 | Samsung ML-2510 Laser Printer
If the paper is jam in the printer
Without more specific information on where the jam is occurring in the printer difficult to provide a specific solution.
However, if you are having problems with paper jams you may find it helpful to work through the interactive troubleshooting guide found on this page under the Troubleshooting tab:
http://www.samsung.com/sg/consumer/pc-peripherals-printer/printer-multifunction/mono-laser-printer/ML-2510/XSS/index.idx?pagetype=prd_detail&tab=support
Under the FAQs tab on the same page you will find 3 guides for avoiding paper jams and 1 guide for clearing paper jams.
Trust this is helpful. Please vote. Thank you. :)
Dec 21, 2010 | Samsung ML-2510 Laser Printer
Paper will not feed unless it is helped and the red alert signal is always on. Can you help?
probably have some debris interfering with your 'paper path'. probably one of the paper pick-up rollers- check the path, try to remove debris, and try again! blinking red led is prob. jam warning! all it takes is a little piece of paper, or other debris wrapped around a "paper feed roller' to mess things up!
good luck!
Oct 08, 2009 | Samsung ML-2510 Laser Printer
The paper does not feed into the printer
Sounds like you have a jam!
The jam always hides good!
Look carefully and get back with me!
Jul 16, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
jasbo
jasbo
