Question about Ricoh Caplio R4 Digital Camera
I took a lot of photo's and now the camera said : Card Error I don't know how to repair it.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 29, 2010
My display screen is showing pixelated noise, or completely black. When it does display, all I get are off colour, horizontal dancing lines.
Camera is defect for sure, but don't tell anyone in the service centre, because they warn you not to take a camera out in extreme cold. You should not se the camera in environments below zero degrees
I'm afraid you can't fix it yourself, and before bringing it to a Canon Certified repair centre, ask them what it could cost.
Mar 01, 2015 | Canon PowerShot G10 Digital Camera
I am currently using a cannon a480 digital camera with a 2gb memory card. i just inserted my memory card into another camera (benq dc2410) and it said card error, needs formatting. now when i placed my...
As long as you didn't format the card your images should still be in there. Get a card reader (usually like $10) and connect this to your computer. With this you can just drag and drop the images to your desktop. Once you do that format the card on the camera you want to use it with and don't use it on any other devices. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Canon PowerShot A480 Digital Camera
1. When camera is powered off, lens will not retract. "Whirring" noise heard 2. When camera is powered up the lens will extend. However there is no image seen on the screen when the camera...
Well If the photos you want to retrieve are on the 15Mo of internal memory, there is not much to do here except to see a repair center.
If they are not on the internal memory, open the Battery hatch of your camera, push on the small card that is close to the battery, then take the card out.
Now you can plug this card directly in a card reader.
If you have a laptop you might have a compatible card reader on it, otherwise buy one, it is always usefull.
Retrieving the photo this way on any camera saves battery and is usually faster than when using an USB cable.
Hope this helps
May 18, 2011 | Olympus Stylus 1010 Digital Camera
I took a picture with my camera the other day, it had been working fine for 5 months, and then all of a sudden beeped and says memory card error, and I can't review any pictures. Connecting it to my...
Use a card reader to connect your card with the computer, as long as it can be detected by your computer, you can try some photo recovery software to rescue the files on your camera card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Oct 08, 2010 | Canon PowerShot A400 Digital Camera
I have a canon powershot sx200 IS and I recently went on vacation and took a lot of pictures using teh SD memory card provided with the camera. For some reason, after almost filling the card I received a...
The likely reason this keeps happening is that these cards weren't formatted in the camera when you first got them. However, don't do so just yet as formatting also erases the card. If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. Now AFTER you've recovered the photos, format the cards IN THE CAMERA USING THE CAMERAS FORMAT FEATURE. Look for it, it's located under the "tools" menu (look for the item stating the card's memory capacity). This should rejuvenate both cards, and prevent reoccurrence.
Aug 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
Losing photos
They are probably still there. Get yourself a card reader and use it to download your pics. f1eb652.jpg
Jul 06, 2010 | Samsung S630 Digital Camera
Communication Error
It suggests that the USB socket on the camera is damaged.
It's not cost effective to repair it, so just remove the memory card from the camera and transfer files using an external card reader. It's usually a lot quicker this way as well.
Jan 30, 2010 | Canon PowerShot A560 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
you may try some card recovery software, recommended asoftech photo recovery that helped me before.
http://www.asoftech.com/apr/
If needed, you may do a quick format of the card, and then use asoftech photo recovery to recover files.
Apr 29, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Retrieving accidentally deleted digital photos from memory card (user error)
I would search google for "file recovery" software and run that on your microSD disk, just like you would a floppy or hard disk and see if it will find anything.
May 31, 2008 | Motorola Mobility RAZR V3
Ricoh Caplio R4 Digital Camera Logo
46 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Greg Cann
Greg Cann
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
