Question about GTCO Roll-Up Digitizer, 30/36" (RU3036)
I HAVE AN OLDER MODEL GTCO ROLLUP II DIGITIZER (3036R), BUT CANNOT LOCATE DRIVER DISK(S)---- WHAT IS THE BEST WAY TO OBTAIN A DISK? B.C.
  • 47 Answers
You can try the Tech Support section at GTCO.COM or vtablet.com,on vtablet the drivers aren't free and will have to be purchased.
Posted on Nov 27, 2010
NEED WIN 7 DRIVER FOR GTCO CalComp Drawing Board III
Drivers for GTCO, GTCOCalcomp or Calcomp digitizers for Windows XP, 7 and 8 can be downloaded from this url:http://www.interworldna.com/GTCO/gtco-drivers.php
If you are trying to use your digitizer with AutoCad these drivers will not work and you will need to buy a driver from VTABLET.com (They provide a 30 day free trial/demo) only works with serial RS232 interface. If your digitizer uses USB then you will need an interface kit for your specific digitizer to convert it to RS232. Most new digitizers come with USB, some have serial but require you to buy an interface kit. Contact your Digitizer supplier.
If your digitizer is a GTCO, GTCOCalcomp, Calcomp or Summagraphics brand, try these guys: http://www.interworldna.com
They do not know about any other brands. Wacom contact Wacom, Numonics contact Numonics. If you have Mutoh or Science Accessories or any other brand you are on your own as those manufacturers have all gone out of business as far as I know.
Dec 06, 2013 | GTCO CalComp Drawing Board III 34180...
Tip
Troubleshooting GTCO Digitizer Products
GTCO put in an automatic diagnostic of four beeps on power-up, with a transducer attached, called Success Tones to tell people that the Digitizer is good.
on May 15, 2009 | GTCO Calcomp 20"x24" SuperL III Digitizer...
Does the drawing board III use WinTab for arcGIS 10?
ALL ESRI ARC Programs as far as I am aware use the Standard GTCO Tablet Works drivers. All GTCOCalcomp digitizers are or were level 1 supported by ESRI and the standard tabletworks driver will work just fine (This only applies to Windows versions of ARC, not Unix or other OS's)
Drivers can be obtained from GTCOCalcomp or from this link at the Interworld Site: http://www.interworldna.com/GTCO/gtco-drivers.php
If your digitizer has a serial interface use the SuperSet code 01 or 11. If you digitizer uses USB then no superset is active or needed (This only applies to GTCO or GTCOCalcomp Digitizers)
Calcomp or Summagraphics digitizers will need to be set to 9600,8,N,1 with High Resolution Biinary output to work with Tablet works. Hope this helps you
Jan 10, 2013 | GTCO CalComp Drawing Board III 34480...
Relocated digitizer and when set up it peeps with message running self test no digitizer
Make sure the Digitizer is set to Superset Code S01, it may also be a bad cable,check all of the cables for wear.
These units do go bad sometimes,so you may have to call GTCO and have them look at it.
They shouldn't charge for an evaluation.
Mar 30, 2011 | GTCO QuikRuler III Module Legacy (without...
Dell M6500 w Eports Dock setup rollup Serial Dig. Tablet Works Can not find (10.09 ver)
The GTCO drivers only recognize Com ports 1 and 2, if you are using a serial port for communications.
If you are using the USB driver for Wintab, the drivers may not recognize the E-Ports.
I would try the USB driver and cable,(CAUTION) the RUD III,gets its power from the USB cable,so don't plug in a power supply and the USB cable.
Only use the USB cable when using the 10.9 drivers.
Jan 11, 2011 | GTCO Roll-Up III Digitizer
GTCO Roll-Up Digitizer... lines appear wavy and jagged
The GTCO ROll-Up is not a high accuracy tablet,it is made for general use by Estimators.
Normal accuracy is somewhere between 15 and 22 mil.
Are there any breaks in the line,this would indicate an open on the grid.
Are you using a Tabletworks driver? Check the options and make sure the correct size tablet is in the driver.
Apr 30, 2010 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
What site is the best site to get the necessary drivers
The best site is www.gtco.com, ther are other drivers on the market but they are not free.
Oct 14, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Calcomp GTCO Roll upDigitizer
Go to the search on your computer and find your tabletworks. Open tablet works and go to mapping. Click pick. Locate your mouse pad on the digitzer pad. Click Apply. This worked for me.
Mar 29, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
Wont recognize gtco digitizer on start up
First reset digitizer and make sure you hear four beeps and only four beeps.
Check the cables from the Quikruler to the interface module, make sure they are in good condition, no cuts, breaks missing pins on connector.
Check cables from interface module to digitizer. A good way to check for an intermittent problem is to bend the cable at different points and check the display on the Quikruler to see if has reset.
Select S01 on the superset code with your stylus or cursor. You get get four sucess tones (beeps).
If none of this works check the firmware version on the digitizer, some J2.0 firmware may become corrupted. When the firmware becomes corrupted, you will hear three(3) medium tones on power-up.
If this is happening it will have to be serviced by GTCO.
Feb 06, 2009 | GTCO Roll-Up Digitizer, 30/36" (RU3036)
GTCO Calcomp Drawing Board III connects but won't function...
I HAVE CALCOMP DRAWING BOARD II BUT MISSING ALL CONACTION FOR IT ( CHARAGE , POINTER , 1/O )
PLEASE WE NEED PAY THIS CONACTION FOR RUN
MY EMAIL SAYEDTEBBIN@YAHOO.COM
Jan 06, 2009 | GTCO CalComp Drawing Board III 34180...
Computers & Internet Logo
155 people viewed this question
Top GTCO Computers & Internet Experts
David Payne
David Payne
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
