Question about Whirlpool LGB6300 Gas Dryer
I have a whirlpool ultimate care II LGQ9858PW1 the problem is that it only heats up for the 1st 5 min if that then no heat
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
Posted on May 25, 2008
  • 29 Answers
SOURCE: We have a Whirlpool Ultimate Care II gas Dryer
Could just be a matter of wires coming loose. The movement and vibration of the spinning could have shaken wires loose. look for any wires not connected to anything.
Posted on Nov 06, 2009
  • 249 Answers
SOURCE: my Whirlpool Ultimate Care II dryer does not heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 02, 2010
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool Ultimate Care II no powerWhirlpool Ultimate Care II no power 1st it would get to the spin cycle and not go any father just hum now no power at all
    this has a kenmore type lid switch, they often break and although seem ok will not allow the machine to spin out. I would replace the lid switch. (you have to remove the two screws at the corners of the control panel and it hinges back to remove the plug to
    the lid switch.) Make sure unit is unplugged first. There is also a 5/16 grounding screw
    under the top of the machine which is in a difficult location. It also attaches to the
    lid switch and must be removed. The plastic channel holding the wiring clips onto
    a lip in the sheetmetal. It takes a bit of patience to get this switch out and skinny arms.
    by reaching between the drum and the top of the machine. Hope this helps.
    Jul 06, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
    Whirlpool Ultimate Care II dryer trips breakers.
    No way to know unless you do some checking. This video shows how to get into the machine: HERE
    I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
    Feb 14, 2010 | Dryers
    Whirlpool ultimate care II dryer will not dry clothes
    does dryer heats up if yes take hose out from back of your dryer run dryer if you have good power air coming out from your dryer i think your dryer is fine you need to clean your air vent. system.
    Feb 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Ultimate care II Whirlpool dryer
    May 24, 2008 | Dryers
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Whirlpool LGB6300 Gas Dryer Logo
    57 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
