Question about Kenwood KVT-715DVD Car DVD Player
DC plug for monitor unit
The yellow wire came loose from the 8-pin plug. Does anybody know what position it should be in the plug? Thanks
  • TicoLC May 08, 2008
    Thanks
  • 111 Answers
Below of the RED wire at the corner
Posted on May 08, 2008
Compaq CQ1-1225 AIO Wont Start at all. Removed all components
Suggestions;
Anti-Static wrist strap connected to ground source, and your wrist;
1) The jack your AC adapter plugs into on the motherboard, is the DC Power Jack.
Motherboard out of case, power to motherboard, take your multimeter and see if you are getting 19 VDC at the DC Power Jack's positive solder joint, on motherboard.
The center pin of the jack is Positive. (The inner cylindrical shell is Negative)
Follow the DC Power Jack's positive pin from the Center of the jack, to the motherboard.
You probably won't be able to touch your meter's Positive (Red) probe, to the DC Power Jack's positive pin under the jack; so touch it's solder joint on the opposite side of the motherboard.
(DC Power Jack should be soldered close to the motherboard, is why)
Of course also touch the Negative lead, (Black probe), of your meter, to the Negative, (Ground) solder joint for the DC Power Jack.
Getting 19 volts DC?
See if there is a cracked solder joint, for any of the DC Power Jack's pin connections to the motherboard.
ANY perceptible movement of the DC Power Jack on the motherboard, indicates a bad power jack, and may indicate a broken/cracked solder joint.
Center pin of DC Power Jack is loose? Bad DC Power Jack. Replace.
2) DC Power Jack is determined to be in good repair? No cracked/broken solder joints?
The next components in the power circuit on the motherboard, leading From the power jack, are P. MOSFET's.
Power MOSFET.
Power MOSFET Wikipedia the free encyclopedia
More information using a prior solution,
Dv6000 power light does not come on any more
Check the links given.
3) The last thing that concerns me, although I probably should have listed it first; is the AC adapter you are using.
Concern is that it doesn't have the 'intelligent chipset' that matches the Compaq CQ1-1225 All-In-One desktop PC's circuitry.
AC Adapter For Compaq Presario All in One CQ1 1225 Desktop PC Charger...
Just my thoughts..........
Regards,
joecoolvette
Jan 15, 2015 | HP Computers & Internet
Front panel connectors
Black or white is negative, color is positive. Pin 1 is usually positive.
Also, If you look closely at the plastic plug, there *should* be a tiny triangle/arrow....that's the "+".
May 18, 2012 | Computers & Internet
I have a dell computer. when i turn on the tower and monitor i get just a black screen on the monitor. i have pushed a few buttons on the bottom of the screen and it just says power save mode please use...
No, it's the Power Supply.
Power Supply has a weak voltage power rail.
The monitor goes to Power Saver mode because it is not receiving a video signal. (No Signal)
This is because the computer is not working.
Dell Support > Dimension 4700 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/dim4700/sm/index.htm
Click on the heading - Advanced Troubleshooting
Is the Power On LED light blinking Amber? (Yellow)
Post back in a Comment.
Regards,
joecoolvette
{You can also test the power coming out of the Power Supply.
The Power Supply in your computer is an SMPS.
Switched-Mode Power Supply,
http://en.wikipedia.org/wiki/Switched-mode_power_supply
It converts the AC electricity from your home, or business, into DC electricity.
There are three main voltages produced;
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
All are DC voltage
Two D cell flashlight batteries produce 3 Volts DC.
(In case you are worried about being shocked.
The 'bad' electricity is contained inside the Power Supply's case)
If you do not have a multimeter, an economical unit can be purchased for around $8 to $12. A LOT of stores carry them. An auto parts store is one example.
Orange wires are 3.3 Volts
Red wires are 5 Volts
Yellow wires are 12 Volts.
ALL 3.3 Volt wires end at the same 3.3 Volt power rail in the Power Supply.
Same with 5 Volt wires, and 12 Volt wires.
You can test ANY Orange wire, or any Red wire, or any Yellow wire.
ANY Black wire you see is a Ground wire.
The red probe lead of the multimeter is the Positive lead. The black probe lead is the Negative lead.
The Positive probe lead is touched to a positive wire.
Orange, Red, or Yellow.
The Negative probe lead is touched to ANY black wire. ALL black wires are a Ground wire.
The function knob on the multimeter is set to DC voltage. (Dotted line over a solid line, with a dotted line under the solid line. The curved S line over a solid line is for AC voltage. This = No)
If there are different scale settings, set the function knob to 0-50 Volts. (DC)
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
I need no color code for 2006 ford taurus
+12V DC Battery(Constant) Red/yellow - Control unit in left side of luggage compartment 17 20 amp Junction box in front center of engine compt.
Switched Accessory Red/orange - In-line with the starter relay 27 5 amp Junction box in front center of engine compt.
Ground Black/lt.green
Remote Turn On(output) Brown/orange Pin 8 of CD changer. Also light green/black between rear control unit (C388B-2) and front panel (pin 4).
Illumination See notes *
Left Front + Orange/lt.green
Left Front - Lt.blue/white
Right Front + White/lt.green
Right Front - Dk.green/orange
Left Rear + Grey/lt.blue
Left Rear - Tan/yellow
Right Rear + Orange/red
Right Rear - Brown/pink
Notes
Information listed in the harness section refers (in this case) to the rear control unit in left side of the luggage compartment.
* Illumination is controlled from the integrated control panel, thru dark blue/white at pin 2.
INTEGRATED CONTROL PANEL has white/red for battery input (pin 11), with fuse no. 33 of 15 amps in the junction box under left side of dash; black/pink for acc. power (pin 6), with fuse 22 of 15 amps in the junction box under left side of dash; red/yellow for hot in start or run (pins 5 & 16), with fuse no. 32 of 10 amps in the same location.
AUDIO connections between the integrated control panel (front) and the rear control unit (rear) are as follows:
R+ dark blue/white wire between pin 9 of front unit & pin C388B-7 of rear unit;
R- gray wire between pin 19 of front unit & pin C388B-20 of rear unit;
L+ brown/light green wire between pin 20 of front unit & pin C388B-6 of rear unit;
L- white/pink wire between pin 10 of front unit & pin C388B-19 of rear unit.
AUDIOPHILE SYSTEM has right and left tweeter speakers branching to right and left front speakers with the same colors.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 12, 2009 | Car Audio & Video
Need pinout for Alpine CDA-7940 head unit
facing the back of the 7940 the top left corner is pin 16 the top right corner is pin 9. The bottom left is pin 8 and the bottom right is pin 1. Only a few of the 16 pins are used due to this unit only having pre-outs, no internal amplifier on this unit. Pin 1 red (ignition), Pin 2 pink/black (interrupt), Pin 3 orange (Illumination), Pin 8 black (ground), Pin 9 blue (power antenna), Pin 10 blue/white (remote turn on), Pin 16 yellow (battery).
Feb 21, 2009 | Alpine CDA-7940
Malfunctioning Garmin GTM 20 fused GPS power adapter
The two red wires are +VE Supply and both connect to pins 1 and 2
The two brown wires are Supply Ground and both connect to pins 8 and 9
Pins 3 through 7 are the traffic recievers digital interface:
Purple/violet connects to pin 3
Yellow connects to pin 4
Blue connects to pin 5
Black connects to pin 6
Green connects to pin 7
Dec 30, 2008 | Garmin GTM 12 FM TMC Traffic Receiver...
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Monitor will not show dvd
you need to put the dvds handbrake wire to a suitable earth point and then your dvds will play fine i think the wirings colour is a yellow with a blue tracer line on the wire if its an alpine dvd player and the same is on all the monitors themselves that wire will have to be connected to a good earthing point but luckily on the monitors they have a black earth wire running to them so just splice that yellow/blue wre into the black earth wire on each headrest monitor !
Feb 13, 2008 | Alpine TME-M770 6.5 in. Car Monitor
Kenwood KVT-715DVD Car DVD Player Logo
80 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
