CANNOT REMOVE BATTERY COVER FROM UNIDEN CORDLESS PHONE
SOURCE: UNIDEN Powermax5.8 cordless phone charging
waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Posted on Jul 30, 2008
SOURCE: UNIDEN ELITE 9035 + 1 (WHITE) CORDLESS PHONE INSTRUCTION MANUAL DOWNLOAD
Try here:
http://www.uniden.co.nz/RESOURCES_MAIN/pdfs/ELITE_9035_OM%20Final.pdf
This is the manual from the Uniden NZ site.
Posted on Aug 29, 2008
  • 218 Answers
SOURCE: Need an owner's manual for Uniden EZ1996 Cordless Phone
Here it is.
http://www.uniden.com/pdf/EZI996om.pdf
Posted on Dec 28, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
consultel1
  • 860 Answers
SOURCE: I have a uniden cordless phone model tru9480-3
With the phone in standby, press and hold [dnd] on the base. You will hear a confirmation tone and the [dnd] LED will go out.
Posted on Sep 20, 2009
Testimonial: "Thanks IT Worked"
How do you open a stuck battery compartment on Uniden cordless phone
keep trying is only thing I know of . perhaps a small screwdriver to pry on it gently
Oct 20, 2014 | Uniden Cordless Phone
I have an older Uniden PowerMax 5.8 and the handsets are old and one is held together with tape. The second hand set was rained on yesterday. It was sorta working but I worried i would short it out if I...
Hello, Terrie.
Sorry for the delay in responding - time zone difference.
First, let's see if we can fix your handset (from Uniden):
1. Remove the battery cover and leave it off for ventilation.
2. Remove the battery pack by disconnecting.
3. Leave the battery cover off and the battery pack disconnected for at least 3 days.
4. Once completely dry, reconnect the battery pack and the battery cover.
5. Recharge the handsset's battery pack for 20 hours in the base unit before using the phone. IMPORTANT: You must unplug the telephone line while recharging the battery pack
to avoid charge interruption.
I believe there is a way to export your phone book to another handset, but not without reviving your original phone. Unlike a cell phone, there is no memory card to remove and transfer.
Let me know what happens.
Hope this helps.
Oct 06, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
How do i recharge my uniden phone battery
Phone's "Status Light" Not Illuminating or Battery Failing to Charge
  • 1.Check that the base unit's AC adapter is plugged into the both the base unit and electrical outlet firmly.
  • 2.Wipe the base unit's handset holder's connectors and the connectors on the bottom of the handset with a soft cloth/rag or pencil eraser to remove any loose dust and dirt from the metal connectors.
  • 3.Place the handset firmly in the base unit holder until the "Status Light" illuminates, indicating the battery is charging.
    4.Replace your Uniden cordless phone's battery, by purchasing a compatible battery from an electronic supply store or directly from Uniden. Turn your phone's handset unit over and remove its battery door. Lift the phone's battery pack up and gently unplug the battery's wire connector by pressing in on the connector's side and pulling the connector free from the phone's circuit board. Battery installation is the reverse of removal.
    Read more: Troubleshooting a Uniden Cordless Phone ' eHow.com http://www.ehow.com/how_7252483_troubleshooting-uniden-cordless-phone.html#ixzz1Wkmk0pxX
    Sep 02, 2011 | Uniden Cordless Phone
    The phone rings but we have no dial tone
    get the imei at the back of the phone by removing battery cover and the battery then go to www.unlockitfree.com.click master unlocking code to enter the imei the master code will then be displayed for the phone
    Mar 14, 2011 | Uniden DECT 6.0 Cordless Telephone...
    My daughter dropped the cordless phone and there is no power to the phone , no display.please tell me how to troubleshoot
    open the battery cover. remove the battery for about ten minutes. plug the battery back in and put the cover back on. then put it in the base (not the stand alone charging cradle) the light should flicker on the base for a second. take the phone out and it should be working.
    Nov 03, 2010 | Uniden 5.8GHz Dual Cordless Phone
    Uniden DECT 1580-4WXT waterproof unit appears to be dead - will not charge or register with base unit. Just bought system at Sam's Club 2 days ago. The other 3 units work fine.
    This phone uses inductive charging because of the waterproof feature. I suggest that you remove the
    battery cover from the back of the handset, unplug
    the battery, and then plug it back into the handset.
    This solution worked for me.
    Jun 21, 2010 | Uniden DECT 6.0 Cordless Telephone...
    Hand set tcx905 will not register on uniden base tru8866
    Remove the plastic battery cover from the handset (but keep the a battery connected), then place the handset on the base. That will enable the metal contacts at the bottom of the handset to touch the ones on the bottom of the base.
    Jan 18, 2010 | Uniden TRU8866 Cordless Phone
    Fell in sink...no longer works
    First of all it is possible to buy another phone if you go to uniden.com.
    As much as the one that fell in the sink, remove the battery cover and battery, dry inside the phone and battery. Then place all parts in a warm room (NOT on a radiator) and leave for 24 hrs.Then reconnect and see if it works. My fingers are crossed for you.!
    Jan 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
    Uniden TCX905 cCordess phone Handsets # 3 and 4
    If the handsets are not currently registered to any base, the SYSTEM RESET menu won't appear.
    If the TCX905 handsets in question are actually expansion handsets from another Uniden Phone System, they are not true TCX905 handsets. To verify, remove the battery cover and battery, then look at the inside label. If it lists the model of a TRU9xxx phone system, your handsets are NOT TCX905.
    Uniden unfortunately has programmed the expansion handsets from SINGLE LINE TRU9xxx phone systems to NOT REGISTER against the TRU9466. (Those same handsets register fine against predecessor model TRU8866 though).
    Jun 14, 2009 | Uniden 5.8GHz Dual Cordless Phone
    Low battery in Uniden cordless phone.
    Unless you have one of the water proof phones, hold the handset with the keypad facing your palm, and the top facing your body. Press very firmly at the endention on the battery cover pushing it in a little and down at the same time. Sometimes they are pretty tight but it should come off with a little effort. If it is a waterproof phone, there are four small screws at the corners of the battery cover that will need to come out before the cover will come off, be very carefull as the screw heads are fairly easy to strip and if that happens it is almost impossible to put it back together and still have it waterproof.
    Mar 24, 2009 | Uniden Cordless Phone
    149 people viewed this question
    jasbo
    jasbo
