Question about Kenmore Refrigerators
My Kenmore all refrigerator is not cooling. The motor runs. What's the problem?
  • Kenmore Master
  • 8,220 Answers
Could be the defrost thermostat or heater. Check them for continuity. Look for ice buildup on the evaporator coils. Remove the service panel.My Kenmore all refrigerator is - a3d4209.jpg1c23403.jpgWhen the defrosting stops the ice builds in the freezer killing the functionality. If that is all ok then check underneith for air restrictions . Dust and lint will block airflow. All fans must be blowing inside and out.My Kenmore all refrigerator is - d761db4.jpgre all of them are going. d761db4.jpgThe compressor relay could be going or gone. This link to servicing apartment refrigerators will give an idea what to look for:
Generic ice box repair guide
Posted on Aug 29, 2010
Refrigerator will not cool down
If the unit does not cool down at all, then you might have a refrigerant leak and be low on gas. Locate the leak, fix, and refill to manufacturer's specs.
Jan 18, 2014 | Kenmore 4.6 Cu. Ft. Compact Refrigerator...
Where is the defrost timer on a kenmore side by side model # 106.58904801
What you should be looking for its a dead fan motor. The condenser fan motor cools the refrigerant and allows the compressor to stay cool with the returning cool refrigerant. If the fan motor is working intermittently then the fridge will do the same. Usually the fan will work for a wile but when it gets hot the lubrication to the bearings becomes poor and the bearings get worn ant the shaft will fall and the rotor will lock up. Condenser fan motor is usually located on the bottom backside of the fridge. Do not run the fridge until the motor is replaced, you can create a whole lot of other problems that will need to be taken care of by a professional. Good luck
Sep 08, 2012 | Kenmore Refrigerators
Not starting after being left open all night.
You may have burned out the compressor motor as it was forced to run all night trying to cool the unit with the door open. The compressor motors in home refrigerators are not designed for running continuously. Call 1-800-KENMORE for help.
Feb 11, 2012 | Kenmore Refrigerators
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
My top freezer will not cool the motor is running but freezer stays hot ,the bottom is cooling ok
My guess would be that the defrost is sticking on...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 06, 2010 | Kenmore 64802 Top Freezer Refrigerator
2 yeaor old kenmore fridge not working, motor runs
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 12, 2010 | Kenmore Refrigerators
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
Fridge not cooling.
If it is an 2 motor unit, just order a charge to the refrigerator... but first check if both motors are running, when making cool.
If it´s the gas charge, the refrigerator must be hot, be careful!
if no one hot, than could have a motor or the protection defect!
Best Regards
Aug 25, 2009 | Refrigerators
Motor runs does not cool
Have a technician check the refrigerant level.
Jun 02, 2009 | Kenmore Refrigerators
Refrigerators Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
