Question about Refrigerators
I have a Kenmore side-by-side refrig model 106.50562990. It has gotten rust spots under the water dispenser. How can I get the plastic trim off safely so I can sand & paint the spots?
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Posted on Jun 11, 2008
docjohn174
  • 943 Answers
SOURCE: KENMORE COLD SPOT REFRIGATOR/FREEZER,MODEL 106
hi thanks for the question if the ice cubes are formed in the tray nicely then you need a new ice maker if the whole ice tray is a smooth sheet of ice the freezer might not be cold enough empty out the ice manually ant try again &lower the freezer temp thanke the appliance doc
Posted on Sep 17, 2008
aborcass
  • 2651 Answers
SOURCE: Repainting doors on whirlpool white refrigerator
oowwwww!!! thats what we call in the refrig biz "refrig cancer" the door itself is actually rusting from the inside out. the older refrigs used fiberglass insulation inside the doors which has a tendency to hold moisture, and overthe years rusts through. the new door use blown-in poly styrene foam far less likey to hold moisture. That being said you could remove the door lightly sand and paint, can of krylon enamal aint should do it, at least for a little while anyway
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: The paint on the front of my Whirlpool
You can purchase a bottle of rust converter at any auto parts store, and then all you need to do is purchase appliance paint..
Posted on Jul 18, 2009
How do you disconnect the ice dispenser in a kenmore side by side refrig
Best bet would be to unplug harness at top of door. 1 screw to remove and take off hinge cover. The disperser trim has 2 indents at the bottom, use screwdriver and gently pry loose, disconnect harness
Aug 19, 2012 | Kenmore Side by Side Refrigerator
Water dispenser doesn't work, side by side, model # GSS22JEPA BB
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Mar 04, 2010 | GE Refrigerators
Water on the floor on the left side of the refigerator
possible water line couplin leak located under left front of refrig behind grill or cracked line.
Mar 01, 2010 | Kenmore 53642 / 53644 Side by Side...
Water pan under water filter fills up...spills all over floor
can you hear water running? possible tha the water filter itself has gotten a crack and is leaking itsel, to fix this removethe filter and repalce it with a new one. if thats not the case, pull hte refrig out and check to see if the fan next to the compressor is runnning, if the fan is not runnnig the water will build up ans well as you compressorwill be overheating, lastly check the incoming wtersupply for a dry rot/crack in the plastic tubing
Jan 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Kenmore side by side unit leaks water onto the floor and the water dispenser has stopped working. When I hit the dispense switch I hear water squirting.
Probably the plastic tube that came from the solenoid is broken somewhere between the solenoid and the dispenser(usually under the refrigerator).
Sep 20, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Not dispensing water
more likely the switch braket has broken. this unit has a bracket that holds the micro switches on small plastic pins and they break easily. you didnt list a model number but you an secure the part thru partsdirect.com and here are the steps for repairing the unit:
  • first unplug unit
  • remove disp cover, look on bottom edge of the cover and you will see 2 slots for a flat tip srew driver carefully pry the cover off
  • you will expose the switch bracket and most likely will see the broken pins.
  • just change the switches and light socket over to the new bracket (dont forget to install the switch spacers)
some models have 2 screws under the drip tray as opposed to having to pry the cover off.
If this doesnt sound like your refrig post a complete model number and I will get you the proper instructions. thanks peyton
Mar 16, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore side by side refrig model 52514100
water on the floor this morning. freezer not frozen
Aug 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
