Question about Toshiba SR C8102 (SRC8102-TA) CD-RW Burner
I have an internal Toshiba CD-R/RW SR-C8102. I have uninstalled and reinstalled it. That did get the icon back on "My Computer." And I removed the drive and put it back in. However, it still does not read CD's.
  • 2 more comments
  • dsjones654 Aug 29, 2010
    You're way over my head. I don't even know what you mean by "windows key R" or how to change registry.
    You're way over my head. I don't know what you mean by the "windows key +R" or how to change registry. I need more step-by-step instructions.
    I have received 3 emails that all give the same instructions. The problem is that I don't know what the instructions mean.
  • dsjones654 Sep 01, 2010
    I definitely want to express my appreciation. When I got the more detailed instructions, it worked! I will also definitely recommend FixYa.com.
  • 4,281 Answers
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall cd/dvd drive drivers then it automatic install it's drivers.
Then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on Aug 29, 2010
  • Hi windows key is on keyboard it is in the left side of keyboard and between control and ALter key.
    Press windows key + R both at a same time so you can see run or go to start menu->run if you use windows xp if you use vista or win7 then go to start menu->search then type in search "run" so you can see run in list then press enter.
    Then follow my email solution locate the registry key on reg editor.
    Let me know if you need further assistance.Thanks for using FixYa
  • Toshiba Master
  • 1,606 Answers
If the BIOS is reading it as an atapi drive or shows cd then the problem is usually hardware which means replacing the drive.
You can buy a new dvd/cd rw for $30 or a blue ray for a bit more.
If you listen to the drive it may be making more noise than it did or it may make a chattering or even a thumping sound. It may have been showing errors more and more before it stopped reading the drive. It probably started off by an error in burning a cd. What normally fails in the drives is actually the heads going out of alignment. The drive itself is actually fine but the heads are not quite sure where they are and don;t have the accuracy anymore to work. We used to realign these when the drives were worth it but these days you just replace it.
Download driver gh22np21
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
http://download.cnet.com/lg-gce-8520b-firmware/3000-2122_4-10203021.html
The new firmware offers enhanced recording speed of some CD-R media on your LG GCE-8520B CD-R/CD-RW
Aug 10, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have an old Gateway with XP Pro with a Toshiba SR-C8102 CD-R/RW drive. It will read cds just fine, but will not write to either a cd-r or cd-rw. I just reformatted the hd and the driver was reloaded...
if you reformatted your hard drive you would have loaded the operating system again and have to set the computer up again
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
hope this helps
Aug 08, 2011 | Toshiba SR C8102 (SRC8102-TA) CD-RW Burner
My sony blu ray drver not play blu ray dice only
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver
http://download.cnet.com/sun-cd-dvd-burner/3000-2646_4-10308060.html
Sun CD/DVD Burner can back up data on CDs and DVDs, store large media files, and compile music CDs. It can burn and save whole ISO files, as well as create multisession CDs and erase rewritable CDs. Sun CD/DVD Burner supports almost all kinds of driver types including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB). The program also supports the ability to drag and drop. Version 3.10 may include unspecified updates, enhancements, and bug fixes.
What
Jul 31, 2011 | Sony BD-5300S-0B 12x Internal BD-RW...
I need the driver of lg gh22np21
you might have to physically unplug the leads for this dvd rw then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools computer management device manager scroll to cd/dvd drives + expand you could see a yellow eclamation mark ! or yellow question mark or a red x any of these you need to update the driver right click select update driver
hope this helps
May 17, 2011 | LG GH22NP21 DVD-Writer - Internal...
Ive bought a dvd rom rw cge-8527b but when i put a cd in (dvd movie or dvd rom nothing happens the disc turn and stop no sign of it the icon stays the same
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | LG (GCE-8527B) CD-RW Burner
Hp dvd rw ds-8a1p drive driver please
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
hope this helps dont forget to vote
Mar 12, 2011 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
I have a dvd burner samsung sh-s223c how do I install it on my computer?
you might have to physically unplug the leads for this dvd-rw then plug them back in this should activate the found new hardware wizard or
hope this helps
Feb 07, 2011 | Samsung SHS223C 22x Internal DVD±RW...
Reading problem
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
Dec 16, 2010 | LG GH22NP20 22x Internal DVDRW Retail Kit...
My cd-rom can't read CD-R??!
make sure that the cd rom is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Nov 25, 2010 | LG 16x Internal Blu-ray Disc/ HD DVD...
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Toshiba SR C8102 (SRC8102-TA) CD-RW Burner Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
