Question about Optimus H-5210 Infra-Red Heater
Heater has been wonderful; I have it in my bathroom. Haven't used it in months due to the hot weather, but Friday night it got really cool & I turned it on as I was undressing, etc getting ready for be; It worked fine. Last night it was similarly cool, but the heater doesn't turn on. Nothing. Nada. Never stopped working b4. Have had it about a year
  • 8,220 Answers
Check the fuse. Most electric bathroom heaters have a fuse that looks like this: Heater has been wonderful; I have it in my - 44651a7.jpg
Posted on Aug 29, 2010
I have a question. I have a Kia Rio 2008 and since a few months now, i'm experiencing problems with the ac of my car. My AC is only cooling when the car is not driving, or when the weather is not a hot...
Does your A/C have a full charge of 134A refrigerant in it?
Sounds like it's low on charge.
USE ONLY APPROVED REFRIGERANT not those cheap replacements for 134A.
If the refrigerant container shows an explosive warning on it DO NOT USE IT.Those can be butane or propane mixes and if you have an car accident you may not want to be sprayed with those in your car interior if the A/C system is damaged.
Apr 08, 2017 | 2008 Kia Rio
The noise is probably the compressor. Maybe the belt could be loose or worn. You may be low on freon. Start with the easy one, check the belt, then freon. Good luck!
Jun 20, 2014 | Cars & Trucks
Hot water will not work in kitchen
leave the cabinet doors open at night . place an electric heater in front of them an leave water turned on a little
Jan 06, 2014 | American Standard Plumbing
2002 Ford Escape - stalls in hot humid weather. Fuel pump was replaced. What are other options.
If you do none of your own work or understand
vehicles,you know your option is a repair shop
& I assume better comunications with them &
some positive results
You haven't really said what you or a shop had
done or tested over the last year
All we do is guess & need some technical detail
Aug 06, 2011 | 2002 Ford Escape
For the past two days I have had to reset the main circuit breaker for the outside unit. It appears to be running fine now. I'm just wondering is this an indication of the compressor about to go bad,...
Bill, first thing, make sure the outdoor coil isn't stopped up with dirt. This will cause the compressor to overheat and possibly trip the breaker. If you you can check the amp draw that would be good. Look on the data tag on the outside unit and look for RLA or "running load amps". Running amp draw should never exceed this number, it should actually normally run 10% under RLA. If its real hot where you are like it is here (109) it will be running close to RLA.
If you coil is stopped up with dirt, etc., turn off the breakers, use you water hose and sprayer and carefully wash out the coil.
If all this fails, and your amp draw is good, change your breakers. Hope this helps , stay cool.. Mark
Jul 10, 2011 | GE Heating & Cooling
Getting really hot water to the kitchen but only tepid hot water into the bathroom and ensuite. Do not need to put on the cold tap at all in the bathrooms but you can't hold your hand under the tap in...
If some taps have really hot and others luke warm, then you might have defective mixing valve, check valve, or crossover on single handled faucet.
http://waterheatertimer.org/Crossover.html
Crossover can also cause stacking event. Stacking could be part of puzzle.
http://waterheatertimer.org/Stacking.html
Once crossover or check valve or mixing valve problem is solved, if you have really hot water to some taps, then turn down thermostat to avoid scalding.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Add a comment for more help.
Jun 13, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
We used to have hot extremely hot water in both bathrooms. One day, the water became warm and ultimately cold in one of the bathrooms. Now, the water is also freezing in the bathroom where the water used...
Your check-valve has most likely failed at the switch.
The flow check valve works by opening when you turn the water tap. When it opens it closes a switch which turns on your heating elements. When this switch fails you will still have water flow, but no heat. Titan has parts for this but you will need to call their service Dept.
or call
Toll free support pesonnel hours (EST): Monday-Friday: 9:00am - 5:00pm
They also have an online support operator during normal business hours here
http://www.titanheater.com/livehelp/livehelp.php?department=2
Mar 24, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
2006 sebring 4 cyl - in cold weather security alarm goes off whether i have it left unlocked - use key to unlock or fob - every morning it goes off - yesterday - when i was leaving work - went to unlock...
I know a quick fix to get it started but you might think i'm crazy to do this:
My 2003 Dodge ram van 1500 does the same thing. I put a small heater on the driver's side floor blowing the hot air toward the door.
I plug in the heater when I get home from workand let it run all night.
The computer for the alarm is under a kick plate near the driver's door next to the driver's seat on the left side. Once it warms up the alarm; it will shut off the alarm and you can start the motor.
Jan 06, 2010 | 2006 Chrysler Sebring
Cuts off in warm weather after about 10 miles
Don't rule out fuel pump. Had a 95 do the same, ran great when cool in morning then when it got hot in afternoon, it would quit. Wait 15-20 minutes & go again, sometimes got me home, other times a few more miles until it cooled down again. Luckily I had access to a fuel pressure gauge. Cool in morning had 49 psi, when it quit, 2 psi. Wait 20 minutes, 49 psi again. If you can drive it around until it starts to act up then run into a repair shop for fuel pressure test it will confirm it. If not, they may need it all day to monitor the fuel pressure & confirm it is pump. If your a gambler, change it & fuel filter. One thing I did get was trouble codes indicating a lean mixture, due to starving for fuel. Have you cycled your key to retrieve any codes yet?
May 20, 2009 | 1996 Dodge Neon
Optimus H-5210 Infra-Red Heater Logo
207 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
