Question about Toshiba Satellite A75-S213 Notebook
Laptop is overheating and shutting down. What are the possible causes?
  • 6,831 Answers
Hello
OK, the most probable cause is the fat that the CPU fan might be clogged with dust particles, hence, not supplying the sufficient amount of cooling to the CPU itself.
Once you open up the unit to clean the fan, i usually used compressed air. you can also prepare new thermal paste on the CPU itself, to further prevent overheating.
Hope this can be of help.
If you do not feel comfortable doing this yourself, you will need to take the computer in to your nearest computer repair store, they will be able to do this for very cheap.
Kind regards
Andrea
Posted on Aug 29, 2010
Whenever I play a video on my laptop it shuts down after a few minutes?
Many laptops don't cool as well as they should - try elevating the rear of the laptop - heavy video usage could be causing the shutdown.
How to Fix Overheating and Shutting Down Laptop
Feb 18, 2015 | Computers & Internet
HP Pavillion tx2-135dx laptop overheats
hi.Fan Always Runs Or Laptop Overheats And Shuts Itself Off
Warning! Before Disassembling Laptop always unplug power and remove the battery.
Laptops that shut down without warning are often experiencing overheating issues. Overheating may be a symptom of age, of clogged ventilation or impending failure, but it can also result from simply using the laptop in a bad location. Before you try to take the laptop apart to look for problems, it pays to patiently troubleshoot the symptoms and see if an easy fix is possible. I wrote The Laptop Repair Workbook to teach basic laptop technology and troubleshooting to regular people and techs in training. The overheating flowchart below is one of twelve flowcharts in the book.wfwmoavismn7iaaaaasuvork5cyii=
May 09, 2014 | HP Pavilion Computers & Internet
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
Laptop just keeps shutting down and won't turn on
it may be one of the causes, but the main reason for it is the power supply keeps on fluctuating. You may call Acer for a possible replacement for it..
Jun 19, 2011 | Acer Aspire 5315 15.4-inch Notebook PC
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
Lately, my laptop (Winbook) has been overheating and shutting down. Any ideas?
3 possible causes for this:
  1. Bad Power Supply....heating up and shutting down
  2. Bad Motherboard...heats up and freezes
  3. Bad Heatsink/processor....fan/heatsink no longer keeping processor cool enough to operate shutting your machine down
If when the laptop overheats, it just shuts down and doesn't freeze or lock up, it's most likely the Power Supply. If it just freezes/locks up, its much more likely that the problem lies with the motherboard. Hope this helps with your laptop problem. Best of luck.
Greg
Aug 24, 2009 | Computers & Internet
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Battery and/or overheating or ?
It is possible that the battery is not charging at all and can't pass electricity to the board. But if its 3yo, its probably really dead.
Also, if you can see a fan not working at all, overheating is also possible.
It is also possible that there is a tiny foreign object capable of conducting electricity, such as human hair, that gets activated at the slightest movement of the laptop by shorting some pins on your board.
So I would suggest to observe more or clean the inside of your laptop if you know how to remove your keyboard.
Apr 28, 2009 | Computers & Internet
Dell shut down automaticly can someone help
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Dec 24, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Toshiba Satellite A75-S213 Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
