Question about Kenmore Dryers
I have a kenmore gas dryer model 110.74894401. When the start button is pressed it sometimes makes a clicking sound and the dryer does not start. However, when the dryer does start it tumbles for 15-20 min then stops. The dryers seems to be getting hot, but its not staying on long enough to dry the clothes.
  • Kenmore Master
  • 2,128 Answers
How old is the dryer?sounds like the motor is bad.i see this when the owner doesn't clean out the dryer,it's not that hard to change out the motor,if it's in good shape and not to old go for it but you gotta clean the dryer out,you need to clean out the duct that the lint filter slides into,if you have a shop vac blow off all the lint on the motor and out of the heating box or tube and vac out all the lint and if the vent line is long remove it from the back of the dryer,go outside and make sure the outside vent is clear and then from the back of the dryer blow out the vent line with a leaf blower,i've seen bird nests blow out of the vent lines,you could have a fire in the dryer or the dryer will run hot and damage parts and your clothes will take a long time to dry.all a dryer does is move air,if it can't your gonna have problems,let me know what you find and how you make out,if i can help you with anything else let me know
Posted on Aug 29, 2010
  • Sal DeAngelo Aug 29, 2010
    the part number for your motor is 279787,the sears sit says 133 bucks but another site says 188 bucks,like i said it's pretty easy to do,if you do it and need a hand let me know
    also it's a good idea to check with a meter if power is going to the motor when the motor stalls out just to make sure but it sounds like it's the motor to me.alot of times when the motor is bad it will make a loud noise when you start it but you say it's a clicking sound so just to be safe make sure you have power to the motor to make sure
My kenmore oasis dryer model #110.67062600 does not want to start when i pressthe start button
if the drum rolls freely, put your hand inside and pull the drum around, it is probably the timer
Aug 09, 2012 | Kenmore Dryers
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore Elite Dyer Model # 11071082000
Hi. thanks for the question. the problem you have is with the coils ,on the gas valve. 2 little coils . replace them. thanks the appliance doc
Sep 30, 2008 | Kenmore 72802 Gas Dryer
Dryer problem
Hi. thanks for the question . It looks like you have a faulty motor . I would replace the motor , thanks the appliance doc
Sep 20, 2008 | Kenmore 72802 Gas Dryer
Kenmore gas dryer model: 97274100
if its makeing a hummin sound grral its the motor going bad
Feb 29, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
