Question about Dell Dimension 2400 PC Desktop
My volume icon has been disappeared from toolbar and Control panel has been not showing sound properties. Why?
    Genius:
  • 1,400 Answers
That is weird.
I would try reinstalling the sound device drivers.Your dell pc should have came with a driver disk,or you can go to dell support and download then for free and reinstall.
Posted on Aug 29, 2010
Volume icon disappeared
if sound is still working just go to start, control panel,sound devices right click and go to properties and click desplay icon
Jan 20, 2014 | Computers & Internet
Sound icon doesn't show up on bottom toolbar
Right click on any blank part of your taskbar, then left click on Properties, a windows titled "Taskbar and Start Menu Properties" will open : click on the "Notification Area" tab, then, under Syatem Icons, put a check mark on "Volume", then click on "Apply", click on "OK" and the "Taskbar and Start Menu Properties" window will close and you will have the Volume (Sound) icon in the Notification Area of the Taskbar.
Sep 19, 2010 | Computers & Internet
My sound is very faint i cant get the volume to come up on the toolbar it says Volume Control Program not installed also when i try to adjust the volume under sound and audio device properties. SndVol...
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Sep 15, 2010 | Dell Inspiron 2200 Notebook
Can not show volume icon on my pc
XP view
Control Panel
->sound,speech, and Audio Devices
->Sound and Audio Devices
->sound And Audio Properties
->check "Place volume icon in the taskbar" box
Classic View
Control Panel -> Sound and Audio Devices->sound And Audio Properties->check "Place volume icon in the taskbar" box
Hope it helps.
Aug 14, 2010 | Microsoft Windows XP Professional SP2
No sound volume control icon disappeared
you can go to control panel, look for sound , then open sound properties and under volume tab put a check mark on Place volume incon in the taskbar
Jul 16, 2010 | Dell Inspiron 6400 Notebook
Volume icon lost from my toolbar
I thing this problem because a SoundMax driver conflict with windows vista.I thing you should update your SoundMax driver (if you have) or if you using the old AVG,upgrade it.
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
Volume Icon has disappeared.
First, right click on the taskbar and select Properties from the right click menu.
Alternatively, you can go to the Control Panel and type the word 'taskbar' in the search box from the upper-right side. Once the search results are loaded, click on the link that says 'Customize icons on the taskbar'.
The Taskbar and Start Menu Properties window will show up on your screen. Here, go to the tab called Notification Area. In the System icons section check the Volume box and click on OK.
The Volume Mixer icon will now show up in the notification area of your taskbar
I hope that this information was helpful and thank you for contacting the experts.
Jan 18, 2010 | Toshiba Satellite A65-S1362 Notebook
Can't turn volume down!
Go into your sound devices from the control panel. You should be able to raise & lower the volume from there as well as putting the volume icon back into your system tray. Hope this helps.
Jul 08, 2009 | Compaq Armada E500 Notebook
I have lost the volume control icon from the desktop toolbar and want to restore it
To display the volume icon in the taskbar notification area, you must select the "Place volume icon in the taskbar" check box in Control Panel Sounds and Audio Devices applet.
May 21, 2009 | Dell Inspiron 1501 Notebook
Loss of volume button
click on start then go to setting then control panel in control panel go to sound and audio devices i n that you will see volume tab in volume ther is option called place volume icon in the task bar just select taht and apply it it will show spk icon on your task bar but be sure that your sound card is properly installed. pls get me back if you need further assistence. bye
Sep 24, 2007 | HP Pavilion a815n (PS512AA) PC Desktop
Dell Dimension 2400 PC Desktop Logo
Alun Cox
