Question about Maytag LAT3600A Top Load Washer
Maytag LAT94166AAE is leaking water...hoses are fine and water distrubutor is not cracked or misplace. It seems to just coming out of the bottom and after taking it apart to try to find the problem...nothing seemed out of the ordinary. Any solutions/help would be greatly appreciated!!!! Thanks
  • av430 Sep 03, 2010
    I think that the seal is the problem but when getting pricing info for the parts to fix it, I got quoted $160! I can buy a new (used) washer for less than that....and save the trouble of pulling the broken one all apart. Thanks for your reply!
  • 121 Answers
Take the front off to see if it is leaking where the transmission meets the tub and if so the tub seal is bad this page should help http://appliance-repair-it.com/Maytag-tub-seal.html
Posted on Sep 03, 2010
  • shawnryan111 Sep 05, 2010
    Go to this page and you will find the parts and tools you need along with instructions on how to replace the seal. If you repair it yourself the repair will cost approximately $120.
    http://www.appliance-repair-it.com/Mayta...
Maytag washing machine leaking
it could be coming from different sources. Most likely is the hose. You might need to replace hoses that bring water to the machine, but first check that they are not loose or have cracks that could cause these leaks to occur.
Jan 05, 2014 | Maytag Washing Machines
I have Maytag LS7800 stackables and am happy with the capacity. I am purchasing side by side machines. What is the capacity of the LS7800?
The washer is leaking. Whenever it starts filling water. I checked the hoses they are all fine. It seems to me it's leaking from behind the drum where the water comes in. I couldn't see behind the drum, should I and can I take the top off and see if there is a clip on those hoses coming in
May 28, 2010 | Maytag Washing Machines
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Water leak from bottom
then you may be leaking from the water pump. maybe is worn out, only way to find it is to remove the cabinet an do a load test an see if it comes from there, if the hoses are fine then check the pump.
May 13, 2009 | Maytag LAT3600A Top Load Washer
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer leaking water from bottom
Probably a main tub seal, big job!
Nov 16, 2007 | Maytag MAV7600 Top Load Washer
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Maytag LAT3600A Top Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
