I have tried to install the rosetta stone (original, not a copy) application disc onto 2 different computers I own. One computer has windows vista and the other windows xp. I get this error message on both.
    Sergeant:
  • 223 Answers
Copy the entire cd contents to a new folder on your hard disk, locate the installer/launcher icon inside the folder "Setup.exe", select it and right click on it, go to properties. under compatibility select windows 98 or windows me. press apply or ok, then double click the icon. The program *should* launch properly and install your software. Its a problem with memory resource allocation being different on newer operating systems. (thus why the added the compatibility function for older programs)
cheers.
Posted on Aug 29, 2010
  • Trevor Groves
    Trevor Groves Aug 29, 2010
    Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
Fatal application 1141
Rosetta Stone Version 4 is compatible with Win 8. and Error 1141 is related to services in your computer i have found the fix at Questions Rosetta Stone Community
Apr 15, 2014 | Rosetta Stone 3 Filipino (Tagalog) Level 1...
Problem: Rosetta Stone msg: 1117 error occurred in the speech component operating system: Mac OSX Hi, I Have Rosseta Stone installed on my macbook pro (osx) and have/used it over a week now....
Try my steps:-
1.If you know removing installed programs from MAC, then please remove this application named-Rosetta Stone.
2. Now, remove all the cables & wires if your hardware audio device & turn off your computer.
3. Reconnect all the cables & wires & start your computer.
4. This time, reinstall the audio driver.
If this doesn't work, then you may try these ones:-
METHOD 1: Perform Step 1 to 3 again & install a different audio driver instead of Rosetta Stone.
METHOD 2: (This is only if METHOD 1 is also not working) Try your mic in any other MAC by installing Rosetta Stone in that system.
Note: You may search for a different audio driver at http://www.download.cnet.com/. Here search in mac column.
For any more support or any questions in future, you are the most welcome to contact me at abmakm@yahoo.com.
Feb 21, 2011 | Rosetta Stone Spanish (Latin American) -...
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
I accidentally moved my Rosetta Stone file to the trash and emptied it in an attempt to uninstall. However, when I went to re-install they said I can't because there's a newer version already installed....
open the trash folder, select the rosetta stone file(s) and click restore. You may need to select a unique directory to install the files to avoid conflict with the other version.
Jan 22, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
My win XP computer crashed with my Rosetta Stone on it a month ago. I just got a Windows 7. Will it be hard to get them to activate the product on my new computer?
You need to contact Rosetta Stone to resolve this. If the software requires activation, they should be able to reissue that you the new PC.
Nov 16, 2009 | Rosetta Stone V3 German Level 1-2-3...
I have Japanese levels 1,2 and 3 for rosetta stone. i installed all the software and entered the activation code. it says my codes are activated but when i open the software i only get a blank screen with...
The problem is related to the FNPLicensingService.exe service and FNInterface.dll file.
The first thing you can try is open Rosetta Stoneto and kill the FNPLicensingService.exe in task manager. This may or may not give you access to Rosetta Stone.
If that doesn't work, install Rosetta Stone on another computer (your license will allow two machines) then copy the rosetta stone directory from program files to the new system. Then open Rosetta Stone and it should be fine.
Before doing either of these things it's best to delete the c:\program data\rosetta stone\tracking.id file.
Aug 06, 2009 | Rosetta Stone Japanese Level 1 & 2 for...
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
