Question about Saeco Incanto Classic Espresso Machine
Hi, I a problem with my Saeco s-class incanto classic coffee machine. The two coffee cup lights are flashing green the water light is flashing red. I prime by turning the steam valve and hardly any water comes out. I opened up the back water seems to flow out of the tank but not through the tubes. what is the best way to trouble shoot this problem?
    President:
  • 1,618 Answers
Try this, when you run the hot water cycle to prime machine and it stops putting out water push in on the knob if that works then replace the tap rod assembly or the whole steam valve assembly.
Posted on Sep 01, 2010
  • lvergara Sep 07, 2010
    Thanks, I tried that but did not work. No water or steam comes out of the steam valve. When I turn on the machine, it is does not go thru the normal start-up routine. I do not hear the normal start of machine when the water normally seems to cycle through, gets warmed up then comes out the steam valve, and then the lights go out. There does not seem to be any water getting warm up. I think water is not getting into the proper area of the machine. Is a part not working like the pump? Or, could it be clogged and therefore no water gets pumped to get heated? What is wrong? Help! Thanks.
  • Nick Brookbank
    Nick Brookbank Aug 16, 2015
    This worked an absolute treat! Thank you so much. the whole problem had me baffled!@ You legend you.
    Problem Solver:
  • 8 Answers
I have the same problem and i didnt find a way to fix it yet
Posted on Sep 17, 2015
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Load the circuit
Hi
It means you need to prime the lines. Push the button for water, then open the knob on the right. When water starts to flow the red light should disappear, and start to warm up. If the red light doesn't disappear, you may have a restriction in the flow meter, or intake line.
Nov 08, 2009 | Saeco Incanto Classic Espresso Machine
How do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Oct 26, 2009 | Saeco Incanto Classic Espresso Machine
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Incanto
Hi
Jul 01, 2009 | Saeco Incanto Classic Espresso Machine
3 flashing lights stay on all the time?
I have the same problem. It seems that the group motor issues. I ve opened up and found the group motor is coming some sparks. I know very well Saeco Magic Cappucino , Saeco range is more or less the same, Saeco incanto, first time deal with it , somebody just brought it to me to check it. I might fix it if find parts for it.
Load circuit means a lot, flow meter, pomps, could be the electronc board, bewing unit blocked up with coffee, so basically there is no water in circuit water or is air in water circuit....You have to check everything,
Mar 01, 2009 | Saeco Incanto Coffee Maker
Inoperable expresso machine
Make sure the magnet in the water tank float up to the top.
Try to make a full cup of water (Tea).
Let me know if i can help you more
Best regards
/Mirran
Sep 08, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Issue
Make sure the magnet in water tank flow up when you fill it with water.
Let me know if you need any instruction.
/Mirran
Aug 15, 2008 | Saeco Incanto Classic Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
727 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
