Question about Roper REX5635E Dryer
Dryer will not get hot enough unless you try 3 times
  • Roper Master
  • 8,220 Answers
You should get into the machine and give it a good cleaning. Look for air restrictionsdryer will not get hot - 632ac3c.jpgdabcc07.jpg Use this GUIDE
Posted on Aug 29, 2010
    Champion:
  • 274 Answers
It could be the heating sensor there are two one up to and another on the bottom, And may have a lose coil.
2 Suggested Answers
SOURCE: whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Posted on Apr 20, 2010
Dryer not getting hot
Try cleaning out the lint trap really well and make sure there is clear airflow in the dryer vent hose (usually long silver tube coming out the back of the dryer). Sometimes lint can build up over time in the hose and impede airflow which causes the dryer to still heat up a bit, but it won't get hot. Without proper airflow, it will not get hot enough to dry clothes efficiently.
Dec 17, 2013 | Whirlpool Dryers
Gas valve no stared
The gas assembly has 3 components and all are wired together. When the gas valve assembly is fired up the sensor, the glowcoil, and the solenoids are all energized at once. But he gas will not come out unless the ignitor is removed from the circuit. It gets removed when it reached 1800f at which time the sensor trips and kills the power to the glowcoil. The energy is now strong enough to open the gas up and allow it out and onto the glowcoil. Over time the solenoids get weak when they get hot. So if the flame sensor and glowcoil both work but the flames don't ignite you will want to replace them solenoids.themobilian_2006.jpg
Mar 21, 2011 | Roper Dryers
Clothes aren't drying....although it gets hot. everything seems to be working ok, including the blower & ignitor. Maybe it's not getting hot enough?? help!
werew
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Whirlpool Dryers
Dryer control doesn't move on less dry more dry setting and will not shut off when clothes are dry.
If clothes are hot then try dryer on timed dry. If timer does not move then timer is most likely bad . Replace. If timer moves on timed dry it is not getting hot enough to click the cycling thermostat.(If clothes are overly hot above 160 then the cycling therm. is stuck Replace.
Oct 29, 2010 | Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Good luck,
Vlad
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
Dryer (electric) seems to heat up initially, then cool off and not get hot enough to dry clothes. What is wrong?
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.(usually located inside the unit on the actual blower housing or inside the vent duct)
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 19, 2009 | Dryers
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Zanussi tumble dryer does not get very hot
Hi, I take it from the description taht you have given your T/dryer is a condenser? If this is the case you could be looking at several problems? 1 it could be the large filter underneath the tumble dryer this could be blocked with fluff causing it not to condense quick enough! 2 it could be the water collection pump? Can you her it running? 3 It could be that half the heater has failed causing it not to get hot enough to dry?
Try these hopefully it should steer you in the right direction!
Feb 09, 2009 | Zanussi TD4112W Electric Dryer
Kenmore Heating Element
There are levels of heat according to cycle and some driers do not use all the coils during low heat cycles. They rarely need replace unless visably broken. There could be a loose connection.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
