Question about Refrigerators
The display on our refrigerator displays a constant "Er FF". we looked up the error code and it said the freezer fan may be frozen. we unplugged the fridge the first time for 4 hours and the code went away but came back an hour later. next we unplugged the fridge for twelve hours and the code went away but again it came back before morning.
  • billturne914 Aug 29, 2010
    the display on our refrigerator displays a constant "Er FF". we looked up the error code and it said the freezer fan may be frozen. we unplugged the fridge the first time for 4 hours and the code went away but came back an hour later. next we unplugged the fridge for twelve hours and the code went away but again it came back before morning. The fridge is cooling as well as the freezer but the display only displays the error code and all other functions do not work.
  • billturne914 Sep 02, 2010
    Yes the solution was exactly right and saved me hundreds of dollars with a refrigerator repair man that was booked for the next three weeks.
    Genius:
  • 1,478 Answers
The ER of course stood for error and the FF indicates it was in the freezer fan motor. There was no fan motor signal for more than 65 seconds. This can be caused by a bad motor, bad connections to the motor or something obstructing the fan blade.
I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far, it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I would say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone who can or a repair person.
Take care.
Posted on Aug 29, 2010
  • gxmaso2
    gxmaso2 Apr 08, 2012
    My LG french door refrigerator was displaying the er ff code after several weeks of the fan running very loudly. I had seen posts about unplugging the unit to let the ice around the fan melt, but most of those indicated it only worked temporarily. When I read this post I thought that I would at least give it a try. It took about 3 hours total, but now that I removed the massive ice jam behind the inside rear freezer panel, the refrigerator runs quietly and is cooling well. As an added bonus I was able to determine why our ice maker had not worked in over two years and now we have our own ice again. Thank you so much for posting your solution.
  • gxmaso2
  • 944 Answers
This problem is due to excess frost buildup in the freezer coil.
Defrost is the problem.
The defrost problem could occur due to three reasons
1)Defrost timer
2)Defrost heater
3)defrost thermostat
1)Defrost timer
Usually the defrost timer could solve this issue.It may be located below or back of the refrigerator.Some times it may be located in the side to for side refrigerator.
Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 30-35 minutes.
Then there is no problem with Defrost timer.
2)Heater and defrost thermostat is located behind the back wall of the freezer section.
This only controls the Heat.After the Defrost timer stops it makes the system warm.
Defrost thermostat could be defective.
So replace it accordingly.If you don't have hand on in it,take it to the nearest service center.
For temporary you have switch off until the frost melts and on it again
post a comment for further assistance.
  • Natarajan Ramasamy
    Natarajan Ramasamy Aug 30, 2010
    Hi
    The fridge will function well.Even it will function well for more than 2 years with the same error code in the display.
    This is like a warning message that defrost system there is a defective one.
    If you replace the defrost defective part only it will not get displayed.
    Some times unplug the fridge and letting the frost melt is the only time being help,you can get.
    Some of My customers have this error code and had thier fridge running for 2 years above.
    The only problem is defrost will get accumulated soon.
    I understand the error code will stay or vanish based on the defrost system response.There is a control board which gets the response from the defrost system.Which says that any one of your defrost system part is defective.
    Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thank you for using fixya have a nice day:-)
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Error on display er ff
Hi, here are the error codes and meanings for your Refrigerator
Error Code, All Error Codes will have an ER on the left side, followed by the error on the right:
Er IF - Icemaker Fan Error - This can be caused by frostaccumulation on or around the icemaker fan. Unplug the unit for 3-4hours to allow this to melt off. If error code persists, call CustomerService.
Er FF - Freezer Fan Error - This can be caused by frost accumulationon or around the freezer fan. Unplug the unit for 3-4 hours to allowthis to melt off. If error code persists, call Customer Service.
For remaining error codes, try unplugging the unit for a couple ofminutes to reset the unit. If the error code persists, call CustomerService
Er FS - Freezer Sensor Error
Er rS - Refrigerator Sensor Error
Er ds - Defrost Sensor Error
Er dH - Defrost Heater Error
Er CF - Cooling Motor Error
Er CO - Communications Error
Thank you.
Jun 06, 2012 | Refrigerators
Refrigerator displaying error "ER FF".
Error Code "Er FF" indicates a problem with the unit's freezer fan.
The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue.
Hope this helps.
Jun 10, 2011 | LG LRFC25750 Refrigerator French Door
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
I have an LG SXS side by side refrigerator that will not dispense water. The display shows FR & FF. If the supply is switched off and then back on again the display resets for a period of time. Over...
Er FF - Freezer Fan Error - This can be caused byfrost accumulationon or around the freezer fan. Unplug the unit for 3-4 hoursto allowthis to melt off. If error code persists, call Customer Service.
Jan 20, 2011 | LG LSC26905TT Side by Side Refrigerator
Door display reads ER FF
All error codes will display "ER" on the left side - that simply means error. In your case your error code is FF - which stands for freezer fan, or in technical terms, evap fan. Open your freezer and look for the vents where cool air blows out - do you feel any air coming out, do you hear the fan ? It is possible your evap fan stopped working or excessive frost around it - are you able to turn off unit and remove the back panel of your freezer held by screws, look for any excessive frost or anything blocking the evap fan - if there is no objects or frost blocking fan, then you have need to call service and have them replace your evaporator fan assembly - also note if your freezer fan is not working, then you won't get any cooling to either your freezer or your refrigerator - If you notice excessive frost and see that it is preventing your fan from operating you can use a blow dryer and defrost manually and see if it works again afterwards - if problem returns eventually then you have an auto defrost problem you will have to get it serviced and check the control board and defrost timer + components. Make sure you turn off refrigerator and unplug when checking things yourself at the back - if you are not comfortable doing this call service.
Sep 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ER FF in display ,DISPLAY IS LOCKED, LOUD NOISE
er ff indicates that the computer on your refrig is not sensing freezer fan operation. a guess as to your problem is that the fan is hitting on ice (the noise your hearing) and teh fan is not able to reach operation speed causing the error code. the fix would be to remove the ice from the fan area either maually or by unplugging the unit and letting it defrost for several hours. also to reset the computer you will neeed to unplug it for a few minutes then plugging it back up. hope that helps thanks Peyton
Feb 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have an LG LRSC26923TT Refrigerator. The display shows "Er" in the freezer temp area and "FF" in the refrigerator temp area. Nothing happens when I press any of the buttons. However, the refrigerator...
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG LRSC-26922 Side by Side Refrigerator
Error Code Er FF
ER FF - found in another post = Error Freezer Fan. Removed freezer back panel (inside freezer), defrosted ice build up around fan. Error message gone for now. Easy fix at midnight - 20 minutes. Will be looking into ice-up cause.
Jul 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Error code ER FF
The error indicates the freezer fan is not functioning properly. The fan supplies cold air to the refrigerator that is why it seems warmer.
The fan may be frozen, try unplugging it for a few hours to let it thaw. Also check to see if something may have gotten into the vent holes in the freezer that could be blocking the fan from turning.
Mar 11, 2008 | Refrigerators
Refrigerators Logo
85 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
