Question about Frigidaire FEF352 Electric Kitchen Range
What does f9 mean - Frigidaire FEF352 Electric Kitchen Range
  • 15,935 Answers
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
I have Electric Ranges the control panel mot working . the light went out and can back on it shows f9
F9 means different things depending on the brand of your range. For example, F9 on a Whirlpool means that there may be a wiring problem while F9 on a Kenmore means trouble with the self-cleaning door latch. Google F9 and your range brand to find out what may be causing it.
Nov 17, 2014 | Kitchen Ranges
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I get an F9 error message when I try to set the oven to bake.
THis is what the F9 error code means;
F9 Door latch failure Replace door latch switch or assembly if necessary
Aug 20, 2011 | Ovens
Oven was off...woke up to oven beeping and the F9 code came up & door is now locked. What is F9??
This waht F9 mean
F9 Door latch Check door latch components.
You will need to replace door latch
Oct 01, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
I am getting error code F9. what does this mean?
f9 codes usually relate around the printer boards or firmware errors you could try uipdating the firmware of the sharp site or look at the printer board connections.. try unplugging machine from wall and then take the back panel off check the conections of the boards and reboot.
Jul 28, 2009 | Sharp AR-207 Copier
Sharp AR-M207 with a F9-00 message
f9-00 means the ar-nb3 and or eb9 print control boards failed to recive all packets involved in a perticular print job. weither its 1 page or 100 pdf tiff raw etc does not matter.
as a printer service technician i can ashure you there is no known all inclusive fix at this time. cycling the machine's power will clear the code.
Mar 18, 2009 | Sharp AR-M207 All-In-One Laser Printer
F9 code
F9 - Door latch supervisory (door latched) - Unlock door and check switches or clock assembly (also called the ERC)
Nov 21, 2008 | Maytag MGR5770 Gas Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
65 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
